[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
Factory restore will semi brick your phone.leave debugging mode on..try rebooting your phone while its still connected to the pc
Tried all 4 ports, multiple times with no luck. It was working earlier yesterday so I don't understand what went wrong. I'll buy a new USB cord and give that a try. Does it matter if USB debugging is checked or not? Also what would happen if I did a factory reset on my phone since it's rooted and running 2.6? Considering all the USB issues I'm having I would like to try and get it back to stock so I can get a new one.
Sent from my SCH-I400 using Tapatalk
Video Player
After I installed SC2.8, the video player doesn't work. Does anybody have a video player they recommend or the *.apk for me to install the stock video player?
Thanks
Also, very dumb question here.. If I buy an app, and I wipe my phone and loose it, is it really gone or can you re-download it without a re-purchase? Has kept me from paying for an app :-)
Thanks again, hope the party was a great time!
Randy
I can't answer to a good app that isn't a root based app like Titanium pro, which I have, but I can state that if you purchase an app through the market, and you wipe your phone, just log back into the market and get your app again.
If your app has a key, download the app and the key. If your app is just the app, just reinstall the app. No need to repurchase anything. I've wiped my phone several times, and every time the apps were no issue to reinstall with payment issue. The only issue was Heroes of Sparta, or some such game, where they said that the app wasn't paid for on the phone I was using. I got it from them for free during one of their promo's, and opted to delete it because it's just a game.
Still get the "USB not recognized...this device has malfunctioned" error. Looks like I might be stuck with 2.6 for a very long time.
hi, i just flashed 2.8, and now for some reason i boot into cwm and i'm now using the orange verison of cwm..not my red one...and i also cant get my phone to mount up with odin...any suggestion? and has anybody else had this problem
EDIT* finally got it working again, hadda reinstall a differnt set of drivers and the correct ones again for some reason...who knows.
When you flash a new ROM on cwm all file it will go back to orange. To go back to red cwm simply flash the cwm all file through odin again.
CWM ALL: MEGAUPLOAD - The leading online storage and file delivery service
Just curious if anyone else is seeing this. When I plug the phone into my PC by usb, the mount as card option will not activate unless you have usb debugging activated. Just a weird minor issue, I thought I would share.
Sent from my Froyo Fascinate using Tapatalk.
yes I see that too.
Here too.
No one seems to concerned about it and I'd forgotten about it until your post.
Yeah, not a big deal as long as you know to turn on debugging, but quite a headache until you figure it out.
No one is concerned about it and it is not a bug or an issue, that is the way it works. You have to have usb debugging enabled in order to transfer files between your computer and your phone.
Did you not read my post on page 242?
I'm running EB01/16 SC 2.6
I can't open attachments? I'm getting this error message:
Sorry! use *#9900# to take log
The andriod Browser (process.com.android.browser) has stopped unwxpectedly please try again later
Force Close
any ideas?
thats a known issue. dl dolphin browser from the market and try it.
nope...same thing..... at one point I was able to open attachemnts.... I can't remember when tho, it may have been before I flashed eb01.
do you know if there is any other way around this?
no. that usually fixed it. if you are willing to start over, wipe data and cacha and dalvick cache. then got to mounts and storage and format everything two or three times. make sure you back up your sd card first.
Hey Mike and putney, I thought the debinged browser was supposed to fix that problem. I know that browser is included with sc 2.8, but I have seen other people post about this problem and installing the debinged browser separately fixed it for them. Try installing the debinged browser, the link is in the first post of this thread.
2.8 was great for the most part, but the more clean these Supercleans get, the more stuff I actually like is getting taken out. I worry that pretty soon these are going to be stripped down to just a phone with no apps and no extras. I'm going to go back to the 1st EB01 bloated version for now I guess. Unless someone can point me to instructions on how to add stock apps and removed "bloat" back onto a Superclean ROM. It's even be nice to have a Superclean EB01/EB16 that retained all the stock apps (such as Thinkfree office), sounds and only removed the Verizon branded bloatware and debinged the phone. I guess this newest version of Superclean has some sort of minimal theme on it so the dropdown info bar only has symbols and no words? Also I notice that a lot of the stock alert sounds are gone. Not to negate all the hard work that is being done at an amazing pace here because it's truly appreciated and impressive!!!!
I went back to stock for the time being. SC was not connecting to my wifi. Now that I am back to stock wifi works again. Any ideas? I have had this issue since at least SC 2.6.
ChuckG73, If you are having that much trouble, try going back to 2.5. It was the most stable, I think.
I went the odin dl09 to odin SC2.5 to flash cwm SC2.8 route.
The other routes kept failing. Try that with droidxcons Odin dl09 and SC2.5. Then get the SC2.8 flash from andenylyne's superclean thread directly.
Reactions: ChuckG73
EBO1 voodoo kernel???
Can I use the EBO1 voodoo kernel w/SC 2.8? I tried the EB16 voodoo kernel, but for some reason, it's not working. if I can use EBO1 voodoo kernel w/SC2.8, please tell me where to get it. I tried the link on this page, but get an error saying the file not found.
Thanks
I understand the concern but I haven't done much trimming lately and typically I add it back as a patch to the first post.
Reactions: Landshark
So I'm using Superclean 2.8, but the only thing that's wrong with it for me is that it won't display peoples pictures on the phone when I'm messaging them at the corner.
I must be a rare bird because I'm not seeing any of these issues that keep popping up.
Adrynalyne, great work.
Status
Ariyanto darmana
