[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
thanks i actually flashed 2.8NV myself and my bluetooth has been working fine, not sure why its not working for others but it seems to be on people running 2.8voodoo
Nah.
The BT issue comes from the kernels I provided earlier today that are true eb16.
Bad thing is, they do not work for BT. Too bad, they seem nice.
I am coming from DXC's post and standupdad told me to post the issue in your page....so here's my step by step about my issue
Contact > create group > add member then you'll see FC
it is very strange that some ppl dont get this but I have this problem and DXC see the problem also.....so I'm pretty sure you can fix this problem.....I believe in you!!!!
Nah.
gotcha, i wasn't sure what the issue was so i was hesitant to flash 2.8 but i'm glad it worked, great rom, appreciate all your work
Irony...
the application logger processcom.michaelrnovak.util.logger has stopped unexpectedly. Please try again.
Hopefully I can pm you a copy of what I captured before the FC.
Is it ok to just use ROM Manager to flash super clean 2.8? have never done it before but it seems so much easier....and drawbacks to doing it this way?
If you are going to use Rom Manager, make sure you flash it with version 2.5.x. Do not flash to their latest version which is 3.0.3 for SC2.8 is not compatible.
ok...how do I get verison 2.5.x?
also..I already tried it before seeing you post and the screen now has a green lloyd droid and a triangle filled with an exclamation mark. what does that mean? did I screw up?
Used ROM Manager to flash SC 2.8 now have Problem
used ROM Mang. to flash super clean 2.8. this is my first time. Once in clockwork recovery mode I wiped device and cache then installed zip from sd card. then got little green droid guy and a triangle filled with exclamation mark. its been there just about 5-10 minutes. is it working or did i do something wrong? read about using older version of ROM mang. but I'm not sure if thats what I need to do, and if so, how do I find the older version? I think the rom mang. I have is 3.0.3
HELP PLEASE!
HELP PLEASE!
OK...hit the menu key and the recovery mode popped back up and written in red it said installation aborted.
what do I do now?
also...now after wipe...can't open market to look for older ROM Mang. version. (force close)
You can't use Rom manager to flash any superclean. In order to use Rom manager it makes you install clockwork orange and you can only flash superclean with red. Here's the link to get the latest version of red here. If you alread have clockwork on your phone, download the .zip from that link, put it on your sd card, boot up into clockwork and install it from the zip. If not you can flash the odin version with odin. Then you can put superclean2.8 .zip on your sd card, boot into recovery, wipe cach/dalvik cache, and install superclean from zip. Personally I do it this way, I think it's more convenient than using odin.
You can use Odin to flash cwm 2.5.x. Get the red version found here. Use the odin one if you don't have clockwork already. Odin can be found here.
Download the drivers to your computer (here
From Droid X:
4.) If your phone is plugged into your computer, unplug it now
5.) If your phone is not powered down, power it down now.
6.) Remove battery from phone.
7.) Launch ODIN on PC.
8.) Plug USB cable into phone.
9.) Plug your Fascinate into the PC via USB cable.
10.) Press and hold the volume-down key until you see a gigantic yellow triangle and your phone will be in download mode
11.) Click on the PDA button in ODIN
12.) Choose the cwm Odin from above.
When finished, remove usb, insert battery. Hold the volume - and volume + and hold power. Samsung will flash twice. Right after the second time let go of the buttons. You should now boot into clockwork within a few seconds. Use the volume key to navigate inside cwm, the power key to select, and the menu key to go back.
I am screwed...I have a mac and have the mounting issues...Now after factory reset/wipe can't set up gmail, or open market so I'm assuming its all google associated apps.
From Droid X:
I got clockwork red on my sdcard from your link...what do I do now.
I AM SO LOST!
I AM SO LOST!
First, relax, you really can't screw up your phone. The worst thing that's going to happen would to installing all of your apps and re-configuring all of your e-mails and etc.
If you are in Red CWM, go to install zip from sd card and use the volume keys to choose the SC2.8 and let it install.
Yep, agree with Odin. Then you will have cwm after as well. Just backup your contacts and apps if you can still boot into your old rom. Best of luck. I had trouble with SC2.8 as well. You are not alone.
Sent from my Froyo Fascinate using Tapatalk.
don't know how to get into CW red...Do I have to be hooked up to computer?
I AM SO LOST!
Try rebooting (take out battery, put back in). Hold down volume + and volume- (just hold the middle of the volume rocker), & then hold down the power button. Continue to hold the buttons down until the samsung flashes a second time, let go at this point. You should then go to a blue screen that says recovery, go to apply update.zip (this is cwm), use volume keys to go up and down, use the home key to select. You should then go into clockwork. Use volume key to go up and down once in clockwork, and the power button to select.
Once in clockwork you can flash a superclean rom, the newest is 2.8.
As far as mac goes, I really have no idea. I thought I remember reading a tutorial somewhere though.
Sent from my SCH-I500 using Tapatalk
Status
Cheezy313Bby
