[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
can you tell me how to install this im new to this staff and i would realy like to have it on my phone. thanks
did you root? if you did you do CWM? if yes download rom manager and start up in cwm recovery and make a back up of your phone in cwm recovery. after that find the rom you want and put it on your sd card. go into rom manager and hit install rom from sd card. make sure you click the wipe data radio and it will install the rom you may also want to use the 12/30 kernel.
I am not responsabile for any damage you do to your phone if you do it this way this worked for me tho.
does anyone kno were the ram should be on this i am around 215-250 still and whats a good way to boost the cpu a bit
swype
so I clicked on the link on page 1 to get the latest version of swype from xda, but could not see any link on that op to click on and download
samething happened to me. but found this way over at xda as well down load the dj05 superclean rom and unzip then take the swype file from the system/app folder then put it on ur sd card and install worked for me
can some one help me and tell me if i am using too much ram and what to do to stop this i am around 260 all the time
You are good. I've seen mine jump from 240-290. If you want to see what's really running in the background use an app like WatchDog from the market.
So a few questions on installing this I saw in the instructions that no MODEM file is attached not sure what that means. Do I need to install this rom with some modem file? Or will this work once I have the DL09(OTA) and did Adry's CWMRecovery/SU Hack.
I realize i may need to install SWYPE again but I never use it anyway.
Also I see some fixes went into the original build as seperate links/downloads are these rollup fixes at the bottom? Meaning we only need to install the latest patch not all of them individually? Thanks for the assistance!
installed super clean and My allshare is gone!!...any help is appreciated...im still a newbie but lay it on me! Love the rom and im very happy with my fascinate!
this rom removes all the bloat, allshare being part of it. if you have ROM manager installed, you can go to "download rom" then go to sonofskywalker and then add back in the allshare apk from there.
installed the rom and now i cant make bluetooth calls it feels like the first droid again were is the bluetooth calling app?:-[
^i got bluetooth back after I flashed the blackmod enhanced theme under rom manager. its under the DL09 theme, in rom manager.
dl09 superclean .4
adrenalyns 12/30 kernels
dl09 blackmod enhanced theme
android peeing on apple bootimation <<(very funny)
hopw that help u.
Flashing the modem?
Can I flash the DL09 modem through Odin having already flashed the rom, or should I go back to stock and start over?
Status
CliffHangerOld
