[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
Adryn, did you change something in the power off function? Where I had that awesome multi-option menu on .9 with the reboot, recovery, etc... options - now I don't have a menu at all, just a strange series of haptics, then either a LP force close or a reboot straight to the animation, no Samsung logo or ability to jump into recovery.
Not sure if something got screwed up on my end, or if you changed something. I've re-flashed twice and it's acting the same both times.
Also does anyone have any clue if the wireless hotspot provided is free now?? So weird...
Are you running a voodoo kernel? There is a voodoo section in red cwm
yeah i guess i never did anything with voodoo my cwm was never red until i got DL30.
At the top it says voodoo recovery.. i disabled voodoo and rebooted now what?
no i tried it again and it did the same thing...
just came up with errors and said installation aborted...
then i tried to reboot and got stuck at the samsung screen...
can anyone shine some light on what my problem could be because i didnt have this problem before using the new cwm
Tried 1.0 for about 20 minutes - had to revert back to .8 - The long press reboot issue is hanging me up. No theme installed. ADW Launcher installed..
I have all the options;
Silent
Mobile Data
Airplane
Power Off
Reboot
Recovery
Download
What rom you coming from?
sc.8
EDIT: this is what i just did started cwm. wiped data then cache then devik cache. then installed new cwm then wiped cache again. then i installed dl30 super clean 1.0. then rebooted seems alot faster
Status
kathynickerbutt
