[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
FYI folks, I was messing around and trying to nail down the sleep bug (put the phone to sleep but never unlocks) and I switched the check mark from Puzzle to Glass Unlock and I haven't seen a lockup since. It's still the stock FroYo slider lock screen regardless of which option I choose, but the Glass Unlock seems to work, whereas the original Puzzle (replaced by the OEM slider lock in Adryn's SC) seemed to occasionally lock up, or at least act like it was trying to call the Puzzle Lock and not finding it - thereby resulting in a black screen with no lock at all.
At least, that's my working theory at this point. ;) And so far, so good!
I know myself and gunnermike have randomly seen this issues with the SuperCleans since about v7. If anyone else has, post it up and see if this helps eliminate it. I'm going on about 16 hrs and no lockups, before I was getting one every 2-3 hours. YMMV.
Scratch that theory... sleep-lock bug just reared it's ugly head again. It took much longer this time, but I'm still fighting it.
Very open to ideas/suggestions!
And BAM twice in a row.
This is weird, I have not installed an app or done ANYTHING besides charge the phone to 100% a couple times and reset the battery meter.
It's about to make this phone unusable in it's current form. I find myself pressing the power to wake the phone and holding my breath to see if it actually turns on or not.
Bummer.
I use one stock widget (music player 4x2), and one aftermarket (Beautiful Widget)
I have the weather clock on my home screen, and the Beautiful Toggles for my Vib/Silent/Plane selects.
That's it. I'm not a big fan of widgets, or the CPU or battery they consume so I avoid them most of the time.
I'm starting to wonder if this doesn't have something to do with Wifi and the sleep settings. I have turned off Wifi and gone back to 3g and so far no more lockups. That could also be why I didn't have any overnight, I typically turn off Wifi while I'm sleeping and the phone is on the charger. Seems like when I lock the phone with Wifi on, I have a much higher chance of seeing the lockup...
And... another theory bites the dust... Only 3g on, no Wifi and it locked up AGAIN.
It seems like I can wake the phone up, and put it back to sleep about 3-4 times before it quits waking up.
I'm going to delete all my widgets and see if that helps.
Edit:
Here we go again. No widgets, no WiFi, nothing. Just a refusal to wake up from lock. I even hear my notifications going off, the phone is working fine it just will NOT come back from lockscreen. Something is screwing with that slider lock.
Going to try flashing that AOSP lockscreen for DL30 over top of this one, see if that works. If not, I'm going to have to roll back to my DL09 setup, I can't get thru 30 minutes without the phone blacking out right now.
Grrrr....
Adryn, did you change something in the power off function? Where I had that awesome multi-option menu on .9 with the reboot, recovery, etc... options - now I don't have a menu at all, just a strange series of haptics, then either a LP force close or a reboot straight to the animation, no Samsung logo or ability to jump into recovery.
Not sure if something got screwed up on my end, or if you changed something. I've re-flashed twice and it's acting the same both times.
i've gotten this as well, also, swype is completely screwed up, I followed these steps but the swyping does nothing, only single button presses work (this is with the battery fix btw)
Battery life is terrible!!!!
i've noticed this too with mobile data on, but when it's off it seems to be better, which IIRC is in line with the whole DL30 battery problems
I have two observations.
2. My phones Menu & Home keys do not function at all. Is anyone else having the same experience?
this happened to me once, i assumed it was because at the first boot of ur phone on stock those are disabled when it's setting up your phone and something in there is triggering that, so i reflashed to stock, set that up, then reflashed it and it worked fine
My battery life is being sucked down by some unknown force. Even before I reinstalled my apps. Not to mention flash is not working. I am still tinkering with it to figure it out . Will let you know if I find anything that will be of help to you or anyone else.
i'm still waiting for a solution to get flash on this rom, asked about it a while ago and got no replies
and i have yet to experience the sleep bug, i think i'm just going to try a different rom til this one gets a bit more polished up, kinda sick of constantly screwing up my phone and trying to fix it (for now)
Oh this blows... now it's locking up faster and faster... Can't go 10 minutes - it's done it 4x in the last hour.
I've got to roll back - this is totally unusable for me. And it's a damn shame, coz it runs like a beast when it's on.
So it's something that is fine on fresh installs, and as the phone gets progressively more "broken-in" happens more frequently.
I'm stumped, but I have to have a phone that wakes up when I need it.
this rom works perfectly fine with swype, and power options. If by tinkering with it, you break something, I can't be held accountable for it. It has nothing to do with fit or finish.
As for flash not working, download it from the market. PLEASE read the first post for more info.
MonkeyGrass, sorry, I wish I knew what the culprit was.
Yeah, me too.. it's all good, that's what leaks/testing is for!! :cool:
I'm going to try the fully bloated release and see if I can narrow down to it being a my phone+DL30 thing, or a my phone+SuperClean thing.
I'll post back and let you know if I get it on the full version.
Thanks for paying attention bro!
EDIT:
Interesting... applied the AOSPLockscreenDL30.zip, and now the reboot/recovery power options are gone from my power off menu. It's back to stock.
Yeah, that removed the hack in my rom.
Let me know what you find. I deleted a TON of framework. Its possible I nixed something in the process.
Hey MonkeyGrass, I've been having the sleep bug once in a while, not nearly as bad as your situation. I'm not sure if this will help you, but i use widgetlocker and there's a setting that allows you to wake the phone with the volume buttons. My phone sometimes won't wake with the power button, but it does when i use my volume button, which for me, i've gotten used to using to wake my phone. idk... it works for me, maybe it can help you.
Looking for mesmerize sms. Does anyone know how to add without changing themes or can we get it added to the rom. So far that's the only thing I miss. Thanks!
Sent from my SCH-I500 using Tapatalk
I put the superclean on last night and it seems the only issue i am having is that after long pressing the power button i phone goes all wonky the screen does not come back on and i have to pull the battery out. What is the sleep-lock bug?
can someone help me i just installed DL30 1.0 and now my incoming call ringtones don't work can someone help me please.
Yeah, something is weird in the power menu code, I think... I'm still getting the sleep-bug with the flashed lock screen for stock DL30, I've deleted some apps, but I think there might be something strange in how that's being called. I can tell the phone is still awake - I hear audio notifications and everything. Something just isn't clicking to wake the screen part up. I can duplicate it now almost like clockwork - if I leave the phone on sleep for over 15-20 minutes, it happens almost every time.
Did you flash DL30BatteryFix.zip??
That's what caused the issue for a couple of us.
Status
jeffeps
