[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
I had an issue with the Home button not responding tonight. Everything else seemed to work but the button would not respond. It would light up but that is it. Reboot solved it.
thanks for the heads up. did you get the haptyc feed back or just the light?
this rom works perfectly fine with swype, and power options. If by tinkering with it, you break something, I can't be held accountable for it. It has nothing to do with fit or finish.
As for flash not working, download it from the market. PLEASE read the first post for more info.
MonkeyGrass, sorry, I wish I knew what the culprit was.
i said i was using a theme, i'm pretty sure that's what was causing it, not your rom, sorry i didn't clarify on that
that's the problem with flash tho, when I try to install flash 10.1 from the market i get "Package file was not signed correctly." that's why i'm trying to ask for help >.>
When it happened to me the light blinked like normal but there was no vibration and it did nothing
if it happens again try restarting the launcher not the whole phone. lets up know what happens.
so i have figured out that themes will cause issues such as bad battery life, lag, and lock ups. i had a theme and my battery was dieing faster then i have ever seen. this is what i did mind you i had the new cwm_froyo installed for recovery:
1. start up in red recovery
2. wipe data
3. wipe chache
4. wipe dalvaik cache
5. wipe battery stats
6. install super clean 1.0
7. wipe chace again
8. wipe dalvaik cache again
9. wipe battery stats again
10. reboot phone
11. once all apps are installed reboot in to recovery again and wipe chache once more then restart phone.
i did this and my battery is good and no lock ups, no bad battery life, and no lag. the phone also runs cooler.
2. wipe data
3. wipe chache
4. wipe divak cache
7. wipe chace again
8. wipe devlik cache again
10. reboot phone
post this on the how to battery thread would ya, thats good info.
So reflashing the ROM fixed my Sound Settings force close issue. Not sure what the problem was though
I'm not having battery issues at all... In fact, I'm getting very comparable battery life to what I was getting on DL09 with a UV voodoo kernel
mine is basicly what it was before i rooted. not as bad as it was before i did the draining the battery thing.
Status
BigHugh
