[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
Not sure that any will see in this super massive post... But wanted to let folks now I am seeing better battery performance on EB01 SC 2.4 after running the bstat reset script manually (not from cwm) as posted by Adrynaline.. I getting crazy good (87% since unplugging 4 hours ago) - Contrast Min, Background and Autosync OFF..
Likewise.
Reactions: Landshark
I'm running SC 2.4... Has anyone else received this force close error "the process android.process.acore has stopped unexpectedly. Please try agaon. It happens when I add or delete a contact. But the contact still gets added/delete even though the force close happens.
Thanks
Thanks
reflash your modem.
Got the error again after flashing the modem you recommended. Should I wipe the cache?
if it were my phone i would say yes. keep in mind you will loose all you apps. you will have to set up every thing again. while your at it wipe data as well. di them both like 3 or 4 times.
Reactions: rgm1266
I'm having a problem with sc 2.4 the problem I'm having is that my camera will fc every time I try to use it. How can I fix this?
I don't want to pay for visual vm. What app are you using for visual vm? I didn't see one on the ROM. I'm running SC2.4.
Thanks
hey adrynalyne for this maintenance script pack w/ wiping the battstats do you flash it through CWM, ADB, or run it in terminal emulator? Can anyone confirm this?
Got the visual VM working. Just download the files Cory posted and move to system/apps folder.
Thanks
Nope... I cleared the cache and data 4 times. Reloaded the ROM and I still get the force close. I can highlight a contact and it will delete with no errors, but when I selct 2 or more, then I get the force close.
Have you had that error?
no i havent. ok, i dont do this often, but do you have rom manager?
The man cannot be stopped
Did anyone else notice in the patches section of post #1 Adrynalyne has a maintenance script pack and that right after it in parentheses he says the maintenance script pack will be included in sc versions 2.5+ :eek:
having trouble here
Landshark pointed me in the right direction as to where to get my questions answered, thanks :)
I'm very new at this and it was mentioned that I have to flash cuperclean 2.4 thru red cwm.
I'm running EB01, if I do that, won't it bring me back to DI01? Also I noticed that in the instrustions to get into red cwm it says wait for the samsung logo to come up twice....mine only comes up once.....
I'm so sorry to be repetive....I'm trying to learn and reading up on everything I can. I know once I do this once or twice I will get the hang of it.
Status
noroldie
