[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
OK, here is my bug (s), any help would be great.
1) installed go launcher because i have scrollable widgets. All my widgets are resetting. Jorte calendar, fancy widget, etc. For example, i have a facebook widget that keeps having to relogin. My jorte calendar keeps resetting back to like its never been synced and I get the "example" calendar appointments. They are resetting while I am doing nothing.
2) Is anybody else having theme install issues. I have tried the honeycomb theme and the updated superdark theme and with superdark i get stuck at the boot animation and the honeycomb causes some sort of force close issue. I am trying to install a theme thinking that may fix my widget issue knowing that themes have taking care of some bugs on previous versions.
again any help would be great. AND YOU GUYS ROCK!!!
ok I just flashed to 2.5 and I was wondering should I wipe the batt stat??? for just in case??? for is it necessary??? any recommend??
I have another question....(got too many questions....lol) when I was running 2.4 I get notified sound when battery was fully charged but now with 2.5 I dont hear anything....
Could anyone please help? I love these roms, and I've got the latest (2.5) installed and running, but there's one bug that's driving me crazy.
The Google Voice Search, which I used all the time on my Droid 1, doesn't seem to work correctly. It can't interface with the contacts, or at least it never produces a contact when you say their name, as it's supposed to. So when I say "text Frank Jackson" the SMS form comes up, but I don't get his (or anyone's) name/number in the "To:" area. You can try 100 times, it never produces a contact, either with the text, call or email commands.
Anyone notice this too, or have any idea if there's something I can do to fix it?
The battery popup was an annoyance to many. Developers have worked to remove it from functioning. It appears to have been resolved/removed/ R.I.P. .. in 2.5..
Thank you Adrynalyne!!
Reactions: ksbc616
there is no fix for this yet
I have not really used any voice commands until reading this post.. and it appears to be about 80% for me (firstname) only contact... If I try to use a (firstname, lastname) contact - I get 0%. Not sure what to make of it....
Edit: gunnermike53 knows..
I think you need to load the nuance patch to get voice commands back.
Nuance is one way to get some voice commands back, but it does not restore the Google Voice Actions, which is what this is about. When it works, it works VERY well. But mine has also been broken for contacts search for some time now.
This video shows more about how it is supposed to work.
Did I mess up flashing the am/pm removal .zip since it was already built into the settings?
What does wiping cache or dalvik cache actually clear? Do either get rid of what I did or is either an adequate method to remove an applied theme?
Just curious, what are we going to see from this (2.5) update? I already noticed the aosp lockscreen, but anything else? I know you merged the EB16 and EB01, but I don't understand what that does.
Anyone notice if the sleep of death is still present in 2.5 yet? I will try it tomorrow to see.
Just curious,
Will this set of commands clear all of my dalvik cache or just certain portions?
I'm entering this in Terminal Emulator
Code:
$su
#cd /system/sd/dalvik-cache
#rm *
#exit
$exit
EDIT: I also am having a problem where whenever I try to delete contacts by going into the soft menu -> delete (this lets you delete multiple contacts), the program will force close everytime. It will delete the contact, but it definitely is annoying to have it force close. Anyone know how to fix this?
I am finding that 2.5 broke Beautiful Widgets. Anyone else seeing this? I sued DroidXCon's odin package.
Status
Jayarealways
