[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
Welp, the Gmail issue we posted on the front page look like might be contributing to your problem. Let's wait for a fix from Google.
true true. also, has anybody had the problem of their brightness setting just jumping up on them?
My phone will not connect to my basement wifi????? everything else I own does.
every time i have seen this it has been been a router reset or a security issue...i forgot what the set up was though but i doubt its that the phone has a problem
@gunnermike or whoever can help.
I think I wanna jump into voodoo. I read through your how to voodoo post and just wanted to know that if I am on 2.4 NonVoodoo, do I NEED to do a factory reset before flashing 2.4 Voodoo or will it flash over just as though I was going from 2.X to 2.Y and just wipe cache and dalvik?
I think I understand the idea of flashing the 2.4voodoo.zip in red clockwork and then enabling lagfix and rebooting... should I be ok? Thanks!
Mine has been randomly disconnecting from my wifi, if I disable it then re-enable it hooks right back up.
no wiping needed. flash and enable.
Reactions: JeremytheIndian
So I had another issue today. I tried to restore a backup I made the other day after messing with my phone last night, and got fc all over the place after the phone booted up. so I went and decided to reflash my rom and cleared all the data and cache and booted and it worked, then decided to install my theme, and out started the force close again. So I then decided to flash again, and it's working again, but dunno why its force closing after I try to reinstall a theme. It didn't do that before, and was running thee theme fine.
*edit so for done reason, if I install a different theme first before the one I want, it seems to work fine...a bit odd
Awesome work Adrynalyne, and I hope things are going better at home. My little guy has been on a nebulizer for a long time and we're praying it doesn't progress into asthma. Its never easy!
Changelog is impressive...yea that frankenclean moniker is funny
Got it up and running with voodoo...checking things out now
Thought the baseband would be the rumored eb16, but it is still eb01. Was worried about a new baseband working with themes.
Just flashed a theme...all good
Status
cmdouna
