[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
The "cwm-recovery-ALL" via ODIN did the trick, no errors after booting into CWM red. Wiped both D-cache and cache and installed SC 2.7nv via CWM red without any problems. Phone rebooted perfect, just have to reinstall Nitro Dark theme.
Thanks for the quick fix!!
after flashing nvfix.tar via ODIN and then trying to boot it boots up into regular blue recovery
I did update.zip into CWM 3.0.0.8 and installed NV2.7 again and tried to boot and it hung up at the Samsung logo again
I did the nvfix2.tar and tried to boot and it is hanging at the Samsung logo
What do i have to do to go from Non voodoo 2.6 to voodoo 2.7? any special steps i should take or will turning on voodoo in red recovery before i flash voodoo 2.7 be enough?
I have read thisbut thst doesnt answer my ? Can I flash 2.7 voodoo ovr 2.6 non voodoo n enable the lag fix or do I have 2 flash a voodoo kernel first?
Try This:
Remove Battery, using odin flash the following in order:
1) EB01DB_DXC.tar.md5
2) cwm-recovery-ALL.tar
After these are flashed disconnect and reboot phone using the power and volume key combo for debug menu.
Choose install zip from SD card.
1) Install the ROM first: super_frankenclean_2_6v
when finished DO NOT reboot! choose install zip from SD card again
2) Install the voodoo kernel second: EB01-voodoo
At this point you could reboot but lets do one more zip
3) Install kernel: eb16_voodoo
Now using the recovery menu, wipe dalvik and system cache, and reboot!
GOOD LUCK! I have no problems.
It's nice not seeing the LG stuff listed in the "Running Services" since I was never using it in the first place. Probably won't help battery life a ton but it sure can't hurt.
Try This:
When in here should I enable the lag fix also wen goin from 2.x voodoo to 2.x voodoo can u just flash the newer 2.x our should I follow all these steps again wen dryn moves on 2 2.8 since hes been rainin roms since the eb01 leak
2.6 includes voodoo, why flash the EB01 kernel? And I'd go with the 2.7 voodoo since it has the EB16 dummy kernel built in so you don't have to flash it.
Status
uobuob
