[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
It will do the conversion for you. If not, at the bottom of cwm red you will see voodoo. select it and enable system lag fix and lag fix on next boot.
2.6 includes voodoo, why flash the EB01 kernel? And I'd go with the 2.7 voodoo since it has the EB16 dummy kernel built in so you don't have to flash it.
Not Sure. Just the way I have had success
I think I was trying to cure a problem with a random noise durring calls and I needed the EB01 Modem or I was just blazing my own path....lol
so I dnt have 2 flash the kernel jus the rom n disable lag fix?
Does the EB16SC26x_DXC.tar that I just flashed have voodoo?
voodoo is a faster file system and has other improvments over RFS.
If you don't know chances are the answer is NO.
Usually voodoo roms and kernels are marked with a V or the dev will specify in their install instructions.
DroidXCon,
Now that my phone boots straight into Red CWM due to flashing the "cwm-recovery-ALL" tar will I be able to use Odin to flash the other files you create? I think I read in a post somewhere that Blue CWM was needed for your files.
no i dont support voodoo for various reasons,,,,and doing it with odin is more work then just flashing it directly
Ok, thanks. I'd seen it mentioned that 2.6 had it and just wanted to know if I had it or not so I knew how to answer future "are you using Voodoo" questions. :)
Status
Jon OapostraphyBrien
