[ROM] t0ast3d de1ight - battery saving/fast/custom look 7-19-10
Not trying to pry, but is there anything close to an ETA on the update?
The build is complete except Beezy420 and I can't get the search button (hardware or on screen) to work so Idk. I think I might have to rebuild it back from scratch :/
Right now it's either the search doesn't work or the settings and add to home pop up menu buttons doesn't have a custom/color icon.
Looking forward to giving it a try! Do you have a link that explains what's in the latest version? Thank you so much for the hard work.
Oh! You added everything to the first post. Nevermind. That's exactly what I've been looking for. You are just more efficient than I am.
Thanks for the ROM, toasted! It's friggin awesome. Definitely noticed how smooth and quick it is compared to stock. Went ahead and bought you a diaper or two for the new kid. :)
I did have a problem last night that may or may not be ROM related. I'm using SetCPU to scale my CPU down as the battery gets closer to empty, and once I got down below 20% the CPU was set to 422mhz at max. When I was running apps on this ROM at that CPU level and a battery below 20% I was getting Force Closes on the Sense Launcher all the time.
I'm gonna guess it's an issue with SetCPU and the CPU clock I was setting it to, but I never had this problem until I put your ROM on. So, probably a coincidence but I thought I'd let you know.
-jp
-jp
Thanks, um it's already customly tweaked for ultimate battery life so that's probably why. I wouldn't mess with it, it's perfect how it is.
and thank you very much for the donation
Anyone else having trouble connecting to the cellular data connection with this build?
EDIT: Works fine. Nothing a reboot couldn't fix. Otherwise, so far so good. Awesome. I can't wait to see what battery savings are like.
Yeah, it will take a minute to get the connection. Think it's because I tweaked it so much lol
