[ROM] t0ast3d de1ight - battery saving/fast/custom look 7-19-10
I'm not picky, whichever is ok with me. Im not sure what the interface looks like. I used the ones that came with the stock phone a few times
On v1 I have an issue where whenever I use the fast application switcher (holding down the home softkey) it seems to erase my "default" of HTC Sense as my launcher. After using the fast app switcher, the next time I press the home key it prompts me for which launcher I want to use to perform that action.
I'm flashing v2 right now and will see if it has the same issue.
Edit: Yup, v2 has the same issue for me.
Look for the thread "home button not defaulting to home". I fixed it in the ROM I'm using (damage) by doing a dirty install.
Thanks for the tip, KSmithInNY... sadly, that didn't do the trick for me. Just reflashed the ROM (t0ast3d de1ight v2)... dirty install, no wipe, etc. Still having the same issue.
Maybe try flashing that over v1? Sorry I'm not a bigger help, I've never heard of this issue before, ever.
do i need to install v1 before i flash v2? orrr can i just flash v2 if i completely wipe from another rom? thanks :D im really looking forward to installing this rom =)
Im still a noob to adding roms and such that i already know howto do- but if i wanna use the kernals how do i add them? same way as flashing the roms? thanks, im gonna do this after work!!
Yeah, you can.
And yes, kernels are flashed the same
I must be some kind of idiot cause I can't find the market.
I even flashed the gapps-hdpi-FRF91-signed.zip and still no luck.
Try a dirty reflash.
And of course that's not going to do anything, it's for FroYo
Ah, didn't know that. That's probably why I can't see the market. New to Android and I was following the Cyanogen nightly thread. So I flashed your ROM and then the Google apps zip right away. Reflashing now.
[edit]
Yup, that fixed it.
[/edit]
Toast, I just flashed your rom and I am curious to how long the start screen with the "t" and flashing lights is supposed to last.. it's been doing that for about 20 minutes.
im not able to flash from RA-evo-v1.7.0.1 i keep getting errors :\
i keep getting ...
E:Wrong digest:
system/app/Rosie.apk
E:verification failed
Installation aborted.
Its stuck in boot loop, reflash but make sure to do a full wipe first. PM me if you need help
stopwatch
