[ROM] t0ast3d de1ight - battery saving/fast/custom look 7-19-10
You can flash version 2, no need to do version 1 first. Make sure you do a full wipe before flashing though. Best thing is to get rom manager from the market and install from sd card from there, check the box that says wipe
so i download de1ight v2 and go to put it on my SD card to put it on my phone...then i look and see this Kernel#1 and Kernel#2 Download...do i need one of those on top of the de1ight v2?
Once I'm actually fully rooted (hopefully later today) I wanna try v2 out. I was a little put off by v1 with all Sprint apps removed but since you brought back Sprint TV in v2 I wanna give it a go now!!
yeah.
You don't need them, but it will improve your phone performance
Kernel one doesn't have touch screen, so flash #2 it's what I'm using
i only did the t0ast3d de1ight v2...should i go back and do the Kernal now the same way i did the TDv2? as far as the TDv2 goes, i guess i did it right, i'm not sure...i have this when i hit menu...
2171d1279699509-rom-t0ast3d-de1ight-battery-saving-fast-custom-look-7-19-10-device6.jpg
i get paid friday...once the check hits the bank donations will be sent your way, t0ast3y lol
EDIT: when i click the Kernel link i get this
http://www.fastbrowsersearch.com/results/results.aspx?sp=1&q=http%3a%2f%2fromuploader.com%2findex.php%2f1xcpj&c=web&s=FDNS&v=19&tid={8A865C64-4C4E-355C-5044-1E4B4763B673}
i still have all the sprint apps tho so i guess i did something wrong...i didn't wipe the phone and just flashed from sd card...maybe i should redo it?
TehMan, as long as the ROM is running smooth you are fine but I can see it is loaded properly. You should wipe in the future for stability purposes but as long as it is working, you are G2G. As far as the kernals are concerned, it is not crucial to flash them but kernal 2 is stable if you would like better performance out of your phone....but links work fine on this end.
i got this so i'm guessing i am good
but i've tried downloading the Kernals through firefox and IE and they aren't working...any mirrors?
no touch screen
Been running this rom for a couple of days and its great. Just flashed the kernel from the mirror above but now touchscreen wont work.
handsome
