[ROM] [Team VeNuM] JellyBomb JellyBean ver 5.1.0 -[LIH] - "THE BOMB IS EVEN BETTER!"
Tried it again last night after installing busy box and it still acts as if I have no backup file
Maybe it's because the backup is on my internal storage?
But that still wouldn't make sense because I flashed back to cm10 and installed my apps from my backup root perfectly, i don't know what's up with jelly bomb
Try this... open titanium menu / settings / preferences / backup folder location
Detect then detect whole device. It will search your phone for backups. When it finds them select use this location.
You have to do this any time you load titanium backup unless it was installed via a nandroid backup.
Would it be possible to flash the 'add back' zips on CM10?
Well, I'm sure it's possible, but, will it work?
Thanks
Oh ok, im using the free version of my backup root tho, not titanium
I think I'm just going to buy titanium and use that from now on
Or just get my backup pro and utilize the online backups
nope, didn't work. I tried Swype and the AccuWeather app. Swype stops working, and lockscreen app doesn't show up in widgets.
I got Swype beta installed tho.
What is the name of the AccuWeather app?
Thanks again!
You're going to have to give us a little more detail. Are you rooted, and what custom recovery are you using? Describe exactly what you're doing, and where in the process you get the error message. Exactly what does the error message say?
well when i power my sgs3 everything is good but it says in factory mode and some things may not work. and i cant get multiview now,,thats about it
well when i power my phone it goes to jellybomb and right befor it starts it says im in factory mode ..now i cant get multiview
I've not used Jellybomb, and I've never seen that message. I'd go to the link Skunkape posted and seek help there.
I'm trying to flash jelly bomb 4.3 on my Samsung Galaxy s3 SPH-L710 and I have not been successful. Do I need a specific gapps I need to download? Help!
Every time I have flashed it, it will get stock on boot up image SAMSUNG GALAXY S111. I know it takes a little for it to fully re boot after a new flash but I've waited up to 7 min and noting.
No need for gapps with this ROM. What is the issue?
sent from a GS3 gone wicked
What version are you trying to flash? I would restore my nand back-up and get a new download to my computer and try again.
fulapmu2
