- Nov 25, 2010
- 15,958
- 2,752
- 0
Sorry, I was only commenting on the flashing multiple zips b/c I was nutz to do it and surprised to find it worked flawlessly! Of course I wiped everything 3x, etc, etc and only did the addons after the initial flash/reboot. I definitely agree that your recommendation and process make for a much smoother transition for those unfamiliar with the flashing process (which I was a week ago) This is just a testament to the stability of the ROM and the work you guys have put into it - Dev and Support.
One issue I am seeing. Running Mini Theme 1.5 - my battery NEVER goes above 96% even after a 24hr charge. I have reset, reflashed, toggled Airplane on/off, all radios off, and it never seems to go to 100%. I even went so far as to install JuiceDefender to monitor and control the battery usage. This works like a charm (especially on battery when the screen is off or phone is idle); however, the battery still never goes above 96% on home screen while plugged in.
Any ideas?
Thanks much!
Thanks for the compliment and understanding. The credit goes to Ragnarokx, I just helped out on testing and input. Did a little modding on the Mini Theme to create v1.5. We do owe a lot to you guys to for all your feedback to work out the kinks too.. Thanks.
Ya those 1% bat mods are picky little buggers. Mine does it too from time to time.. Seems like if I unplug then plug back and it usually will pick up that few extra percent. Even stock battery meters do that if you pull up your battery stats, they always hang up at 96 or 98 percent.
