[ROM] TrulyEpic Rebirth v1.5 AC - no planned EB13 update :'(
Hey ragnarok i've been meaning to ask this about spare parts, in the market it doesn't show as and updatable file,but gives me the option to install it :)
if i do this, will it overwrite the one thats installed already? or this is separate?
holycrap i just uninstalled SWF player and now everything is forceclosing on me wtf?
waited for the card scanner to finish restarted the phone, and it still force closing fk
ack no solve, and all i did was uninstall darn it ,so my final result, having to restore to my latest backup.
Drat.
Drat.
It might not be the player, what else did you do, did you install anything? I'm guessing your restarted after uninstall, other wise why did you restart the device?
I had the same issue when i restored some bad data...
I sometimes find like some program settings are being reseted after a soft reset(vol up+power+cam button ), either PowerAMP Player, cham sms program.
For some reason I've dropped off Latitude and had to re-join several times, maybe I should stop pulling my battery without shutting down when I swap. I'm getting too bold.
People who say they're getting 10+ hours aren't making phone calls I guess.
Separate issue, when I leave the keyboard open and lock the screen, the keyboard randomly lights up, anyone else seeing this behavior?
Yes I've seen that behavior before on the open keyboard. Weird. Not to concerned with it at the moment.
The 10+ hrs of usage is so hard to judge from person to person. Everyone has different methods of using their phone. Overall I can't really complain for stock battery and the amount of usage I get out of it. Sure I would like better but until we get custom kernels to control voltage/battery usage better there is no sense in complaining about it. :)
I just updated the swf player and im like.. eh i don't need it, so i uninstall it, and why did i reseted the device? just testing purposes as we previously were doing before to see if any software is at fault to some of the phones problems before :P, and in the spare parts program i set the option to aggresive >.>. could that be at fault?
unlikely, my spare parts is set to aggressive also. Did you by chance accidentally boot into the old clockwork (2.5)? or use rom manager to restart your phone?
It should overwrite it. Go ahead and download.
Need help. I installed as asked.everything seems fine but text mesaages. Its not receiving but i can send. What did i do wrong
ragnarokx, any chance you'd be able to remove the "done charging" vibrate notification from the next version? Love waking up in the middle of the night to that... :|
Reactions: dzitran
The first post in this thread find the link to Restore Stock Apps. Go there and you will find the link to download the file. (Flash the file using CWM3)
Yes I believe that is the stock messaging app without the bubbles. I haven't downloaded it myself, but I think thats correct.
Maybe I'm a moron but I can't find the link to Restore Stock Apps. Where should I look?
Thanks
Don't think so, i never installed CW2.5 nor do i have Rom manager though, i just soft reset the phone(volup+cambutton+power) and let it cycle to the phones desktop launcher and thats when everything started to crash.
crazy... did you restore your back up and everything works fine?
Lauren12
