[ROM] TrulyEpic Rebirth v1.5 AC - no planned EB13 update :'(
K9 Mail and MailDroid seem to be popular - might want to check those out.
Flash this in Clockwork to get back your emoticon key.
Yep this is an awesome rom, kudos to ragnarokx. The only issue i've had is launcherpro will take an extremely long time to load after bootup and sometimes goes on the brink of crashing where it consumes 60mb of ram when normally it's around 18. If i terminate it it reloads fine again lol.
I installed LPP v0.8.2, and made it my default launcher. Rebooted a couple times, and no noticeable slowdown. You might want to try going to Settings>Applications>Manage applications>All>LauncherPro>Clear data & Clear cache, see if that helps.
Again, thanks!
Very welcome :D
in order to flash this... i do what.. rename it and move it to sd card? and then using the orange text screen apply from sd card? (what do i rename it to.. and if im wrong... how do i get it to work.. i know i dont unzip on my pc)
ahhhh! :) nvm. again. i think im finally figuring this out. i got it to work. thank you for all the help! :) :)
why does my phone keep on reeboting cycle when i install a app. it does it in the first 5 min of powering on the phone. i have 1.2 installed lates
Ragnarokx--i have 1.2, also flashed over the power button zip for while on calls--i've noticed the proximity sensor isn't working on phone calls--screen doesn't turn itself off when phone by face, doesn't come on when done talking--help?? Thanks again.
What app did you install?
Try flashing this via Clockwork: link.
addons
now... if i want to install some of those addons... the mini theme, TW lock screen, sprint VM, and samsung/tw apps... how do i do that? from the orange text screen 'from .zip' off my sd card??? or extract first?
and what is included in those sprint apps and can they be selectively deleted. ie- i liked sprint navigation. its the only bloatware i want back. is it in there and can i delete the other sprint apps once installed with that pack???
sorry for so many questions.
Don't extract the add-ons - just place them on your SD card and install using Clockwork (recovery screen with orange text).
All the Sprint apps are included in that zip. After you flash it, use the SDX Stock App Remover to uninstall any that you don't want.
TrulyEpic Rebirth v1.2
w/
  • Mini Theme Lite
  • Restore Bubble SMS - also stops SMS notification if you use Sprint voicemail
  • Custom Font ⁵ - from the Bonzai4All ROM
  • Sprint Voicemail
  • Revert to Smiley Key
This right here is perfect for me, only thing else I can imagine is screen capture issue, and the landscape unlocking fix and Id be one happy g33k. :p
Either way thanks again,
ragnarokx
AHHH
i installed mini theme, custom font, sprint VM, sprint apps, samsung/tw apps...
and now it looks like stock. noo! i dont want stock. i loved the feel of trulyepic... how do i fix it???
ie- what do i uninstall to make it feel like TE again? (it looks IDENTICAL to stock android now. )
:) thank you yet again. i know ive been asking a ton tonight. but i had never done anything like this before. and i have to say... im glad i did. soo cool. thank you for the help.
