[ROM][TW4.3][MK3] ヅ Wicked Sensations Rom v0.2 ✭myHUB✭Clock Mod✭Awesomeness✭1/6/2014
Re: [ROM][TW4.3][MK3] ヅ Wicked Sensations Rom v0.2 ✭myHUB✭Clock Mod✭Awesomeness✭1/6/2014
It seems to me that the ad blockers now aren't working as well. I'm using adaway and even it doesn't stop them like it used to.
sent from a GS3 gone Wicked
Thanks Sean. I will give ad away a try.
Anyone know how I can change the colors of everything (toggles, lock screen clock, icon, etc.) to a custom color?? I want either all neon Orange or Yellow color to match my wallpaper.
Wanting to install this rom, currently running cf, lost root stupidity, 4.3 ota, mk3, can I write over with this rom or dl original prior?
Thanks
Paul
There isn't a way to change the colors like your asking, but you might like the anakonda theme.
http://forum.xda-developers.com/showthread.php?t=2658422
Thanks
Paul
Do you have root & custom recovery? If you took the 4.3 update, you may need to start here.
http://forum.xda-developers.com/showthread.php?t=2541900
FYI...there is an issue with gmail since the google play services apk update....its being worked on and a fix is near. In the mean time you may have to uninstall gmail...boot to recovery, wipe cache & dalvik...dl gmail from playstore.
How do you uninstall it?
Using a root explorer such es file explorer.
Thanks for this info Sean! I just noticed gmail wasn't working yesterday. How can I uninstall gmail though? There is no option to uninstall it.
Edit: Nevermind! I see you answered that right above, lol!!! Thanks for your help!! :D
I had to use titanium backup to uninstall, then went to play store, and downloaded it. Easy peasy
fulapmu2
