zeldalink14
- Jul 5, 2011
- 13
- 0
- 0
I tried another theme and the SMS problem went away thanks!!
I will try another app and let you know what happens thanks
torch hes saying the screen is split it is to in mine on boot and welcome screen rebooting i think fixes i reflashed because i put in bobz gapps and it did it again
Torch also my hard key lights aren't going off
Sent from my VM670 using Xparent Pink Tapatalk 2
Torch also ad away says not enough room on partition this is weird I don't thing wiping data and system is working I'm using jerryscripts cwm green recovery what recovery should I flash ? I'm struggling bad . Thanks any wiping ideas?
Bro wipe everything, not just system and data, follow instructions in the OP please?
and i've noticed the notification bar thing to, all you got to do is open an app like the play store or Messaging and it'll return![]()
and yes, Alot of bugs are being reported this buildbut I'll try to release another one soon hopefully that will fix most problems
Torch also I don't have a permanent capitalization on keyboard.
Great Rom so much quicker and better then stock I had before. So far I have 2.0 Do I need to wipe everything to upgrade to 3? Meaning I have to reinstall all my apps etc? Even with that backup program it is still a apain so I hope not![]()
Torch also to no avail has my status bar came back I think im reverting back to last build backup. beats audio worked for me ,Also holding home key doesn't bring up current running processes like last build.
Dude, Im sorry, but it totally does, you seem to be the only one with SOOOO many issues, you gotta remember not all OV's are the same, did you do the ZV9 update? cause that might be causing all of your issues, and you are wiping correctly![]()
