ARCHIVED: [ROM][WIP] Unofficial CM7 (Gingerbread) - 8/19/2011
Status
Not open for further replies.
Re: [ROM][WIP] Unofficial CM7 (Gingerbread) - 7/9/2011
don't know if this has been happening to anybody else, but every time I turn on WiFi through the notification power widget my phone reboots itself(it also happens with WiFi Hotspot). Is this rare? or a common bug in this ROM?
I haven't tried to enable through the power widget yet myself. I will check that out. I do know that I have had reboots when I am overclocked. But I don't seem to have them at stock speed. I take that back. I have had a reboot at stock speed after clocking it down from a higher speed. I found that if I reboot the phone and do not OC it at all it works fine, but the moment I OC and drop back down to 600, I start getting periodic reboots when enabling hoptspot. I don't remember having the issue with wifi though.
FWIW I use the notification power control all the time to turn wifi off and have never had a reboot because of it. With or without overclocking the phone. I however do not use hotspot so I cannot help there.
I use hotspot and wifi from dropdown menu and haven't had issues with rebooting. I'm overclocked as well.
Did you clear everything in the recovery menu before flashing? No its not common. I haven't had issue with mine. Read above.
Re: [ROM][WIP] Unofficial CM7 (Gingerbread) - 7/15/2011
Updated build in OP. I have not flashed it yet myself. Please make sure to nandroid before flashing. I am not really sure what the updates entail. I know blarf was working on some audio issues with the headset. Other than that it should be synced up with current CM trees.
yes, i did clear everything. I followed all the steps as described in the first post. I went "mounts and storage menu and format boot, data, system, and cache"
Wifi works fine at the moment, but there are some instances when I turn on WiFi and the phone reboots. I just thought I should bring it up since I found it rare that I pressed WiFi and all of the sudden BOOM (a reboot).
If anything i'll try not to use WiFi as much and i'll just use 3G. Thanks for the reply's everybody. :)
Just flashed, will report any issues/fixes I find.
Can you do us a favor a add a date to the build names? Makes it much easier to keep track of things ;)
I'll add a date next time. Not sure when that will be though.
Reactions: vicvon
do we need to wipe before updating?
You shouldn't need to. Try it and let me know. Just nandroid first. I always wipe before instal of even updates, but it may not be necessary.
Do I have to flash Gapps or can I just download the ones I want?
How to Install
1. You must have some form of ClockWork Recovery (I use Xionia recovery)
2. Make a Nandroid Backup - This should always be done before flashing anything
2. Wipe Everything!! This means go to mounts and storage menu and format boot, data, system, and cache
3. Flash ROM
4. Flash Gapps
5. Reboot
How to Install
3. Flash ROM
4. Flash Gapps
5. Reboot
...... this is when coming from another rom, not updating.
I am getting a LOT of FC's when I use Words With Friends and I don't know why. I used to overclock to 748, but I turned it down to 600 and it still freezes. Any suggestions?
Its the ads that make you force close not the app itself.
I searched this Thread and couldn't find the answer anywhere so I'm going to ask. SORRY IF IT"S POSTED ELSEWHERE.
Will Nick7's Roam Access Control work with this Rom? Or any for that matter? Has anyone tried this?
Thanks!
Status
nosrejocius
