ARCHIVED: [RoM] YOUR-MOM-ROM v.1.1 - Updated 11/27/11
Status
Not open for further replies.
Re: [RoM] YOUR-MOM-ROM v.1.0 - Updated 11/14/11
Wow, just went from...
1. - RebornROM v2.2.4
2. - ZVD to ZVH Update, via this thread...
http://forums.androidcentral.com/lg...w-rooting-ls670zvh-links-root-zvd-zv9-57.html
3. - Re-rooted
4. - Re-installed Xionia
5. - Flashed YourMOMROM
6. - Just enabled Data2EXT with modified script.
...I feel so good.
BJ
silly, slightly unrelated question, but is that the easiest way to go from ZVD to ZVH and reborn to your mom rom?
There's two separate screen issues, and you haven't made it clear which of them you are experiencing.
1) Screen garble. This should be fixed for good.
2) Double-tap. This was never fixed and nobody ever said it was. I still can't determine what is causing this, and it is also happening somewhat on another LG device's ROM that I ported to the Optimus S. Either it's a deep internal issue with the kernel, or LG effed up the Gingerbread software on their phones :confused:
My mistake. It's the double tap issue. For some reason on v7.0 I get absolutely no double tap issues and it runs smooth as butter. On 7.1 the double tap issue is more prevalent.
Does this ROM include EAS bypass (bypass Exchange administrator)? The Exchange server I connect to forces the use of a PIN to unlock, and all of the past ROMs I have used (Reborn, etc.) have included EAS bypass. GRom apparently doesn't, and I'm not sure about OptiROM.
UPDATE: Your Mom ROM does not include EAS Bypass. Is there a possibility that it could be added in an update?
Thanks
Check this out. KPSmith posted about it on G+. Amazons free app of the day.
You can click on my G+ link in the upper corner of this post to see it.
http://www.amazon.com/gp/product/B0...ag=hawk-future-20&ascsubtag=UUacUvbUpU1413468
Reactions: generosity
what happened to the alarm/dock app that is nomrally built in to these roms?
is there a way for me to get it back? i like the light up clock when it's plugged in.
I noticed that my phone won't charge on my car charger but works fine on the computer and wall chargers. Don't know how long it's been that way. I tested the car charger with another phone and it's working. Is there a way to fix this?
Unfortunately this is a bug with ZVH, at this point in time, there is no fix for this other than trying another charger. I personally purchased a new one and now I have no issues.
Reactions: B-rye33
Quick question, does the ap2sd zip for your mom alpha also work on v1.0? Also, is there a fix for the fc's on the calibration of HTC_emi keyboard?
Sorry it took so long, but there is a link in post #3 for the calibration tool fix as well as other extras to flash.
Reactions: Titus37 and dobbs69
Would it be possible to change the ROMs boot to something cooler? lol :D or maybe add the old froyo boots :cool:
When will themes be ready for Your MOM? She wants a new dress :-$
Is there a way you can provide the power control toggles in drop down mod so we can use in any ROM :)
I have flashed this ROM and gRom and when in either one I have no service. When I restore and go back to what I backed up I have service. I flashed your data2ext and that has service also. Is there something I need to do? Seems like the MDN and MSID are not transferring.
Thanks for the keyboard fix ,also love the " wake by power button only "zip . I really needed that one. I carry my phone in my tool pouch . Anyway , thanks for all your work . I've noticed you do a hell of a lot of work for our optimus phones . Kudos for your themes too .
Reactions: jstntp
Which baseband version are you running? ZVD (froyo) or ZVH (gingerbread)?
Status
Wrapcart
