ARCHIVED: [RoM] YOUR-MOM-ROM v.1.1 - Updated 11/27/11
Status
Not open for further replies.
Re: [RoM] YOUR-MOM-ROM - with POWER CONTROLS ! ! !
Do I need to use the noiq.zip since u already took it out or is that to put it back in? Just wondering cus in first post in romoved apk u have the noiq listed so I was just wondering. everytime I try to retry a download wen it fails it just force closes the browser I an it dont do amything I liked how I could retry a download or go an look at the download history an with the new download all files apk I cant or can I an I just have it set up any ideas?
Thanks
ps: rom is running great
Thanks
The noIQ.apk that was removed originally noted in the first post is different then the noIQ patch in post 3. The patch disables the service from running in the background. It's been attempted to include this tweak within the Rom itself on a fresh install, but results in a bootloop. Nick and KSmith figured that out with nameless/Reborn Rom. The only way currently to apply it is to flash the modified file after the Rom has been installed.
The .apk that was removed initially is just Sprint bloatware.
As far as your download issues, I'm not sure what your exactly saying. I just tried it and it downloaded fine from my phone.
ok an about the download I just vant get into it the app not the download file. Lile wen I go to the app download all files it wont show me my recent downloads an wen I try to press on the download from the notification bar it will just force close the browser
Ok so tryed to download something an I lost signal an it faild went to notification an clicked on it an it just foced closed the browser an it wont let me go into downloads so I can see my activities an retry the download not sure what to do.
wen I try to go into the download all files apk it just shows me a how to guide an thats all
Wipe everything in recovery and do a fresh install. Dont add titanium backup or anything else... then try again. Sounds like an individual issue. I cant recreate it.
Sent from my PG06100 using Tapatalk
We will take a look at that app. What browser are you using, stock?
@Don
Ok good. Im unable to duplicate the issue. Maybe someone else has had the same issue. Sorry for the trouble :)
Ok, so far I love this rom... few ideas and observations.
Before this I was using REborn rom on ZVD and it seemed far smother and functional.
If I apply overclock at boot it tends to freeze
GPS fails frequently
If you have many notifications (i.e. mass install of apps) they will cover the center clock
The default launcher seems to run so smooth but Zeam runs like crap which is odd
Certain apps don't show up in the market anymore like Handcent but I think that is a Google issue
I have far more dropped calls now and the service in general seems to be worse since ZVH
I would love to see the reboot/recovery mod added to the framework
I can't get apps2sd to work either... every time i try to move it fails
tried installing dark tremor's a2sd scripts and used the gui to apply but it only seems to work for SOME apps... i still end up filling up my internal storage
I really think I'm just going back to ZVD and REborn, only truly stable rom and sw i've used ever with android. I'll keep my eye on this though and hope we can make some improvements
Thanks for the observations and ideas. Unfortunately, about half of what you are noticing is a byproduct of zvh itself. Although I will say I have reverted back from Zeams latest update, because...... well.... it sucks. The version prior is smooth as butter.
We will continue to try to make zvh a better experience for all.
Thanks for checking out Your Mom.
thanks for the insight from someone upgrading from ZVD and reborn. this rom looks great but I'm not entirely sure if I want the ZVH bugs :/
"Changing to 5 or 7 home screens:
1. From your home screen, press the physical menu button on the bottom of your phone. Should look like 4 squares.
2. Select home settings and change it to 5 or 7 home screens depending on your preference."
How can I make it 3 home screens?
You can't with the included launcher. Download an alternative launcher if you want complete control of the number of home screens.
"With this launcher the options are only 5 or 7."
Thanks. didn't know if there was a way to mod it.
Will look around for the one with 3 screens. lol
Status
s1atoshi
