ARCHIVED: [RoM] YOUR-MOM-ROM v.1.1 - Updated 11/27/11
Status
Not open for further replies.
Re: [RoM] YOUR-MOM-ROM - with POWER CONTROLS ! ! !
"With this launcher the options are only 5 or 7."
Thanks. didn't know if there was a way to mod it.
Will look around for the one with 3 screens. lol
Launcher Pro lets you choose any number from 1-7 of homescreens. This is my favorite as it has a scrollable dock too, which is nice for a few contact speed dial possitions !!
launcher pro, thanks i'll check that out.
here's an issue i've found. stock browser, click on menu/more/downloads and it FC's. OC 748 otherwise regular install.
Yes, I have noticed this. Going to work on a fix for that for the non alpha release.
Reactions: kenny70452
Is there anyway to include the updated music player in the non alpha release?
Right now I'm oc to 748 no problems.
Ok, so far I love this rom... few ideas and observations.
Before this I was using REborn rom on ZVD and it seemed far smother and functional.
If I apply overclock at boot it tends to freeze
GPS fails frequently
If you have many notifications (i.e. mass install of apps) they will cover the center clock
The default launcher seems to run so smooth but Zeam runs like crap which is odd
Certain apps don't show up in the market anymore like Handcent but I think that is a Google issue
I have far more dropped calls now and the service in general seems to be worse since ZVH
I would love to see the reboot/recovery mod added to the framework
I can't get apps2sd to work either... every time i try to move it fails
tried installing dark tremor's a2sd scripts and used the gui to apply but it only seems to work for SOME apps... i still end up filling up my internal storage
I really think I'm just going back to ZVD and REborn, only truly stable rom and sw i've used ever with android. I'll keep my eye on this though and hope we can make some improvements
Were you able to get Darktremor app2sd to work for you? I was able to flash it and seems to be working fine.
Waiting patiently for 1.0...........
Has the IQAgent fix you published here been tested for any other ROM's? I'd just love to remove that intrusive mess from my device, process and all.
I do know somewhere in opti_rom thread it says not to use the gui from the market with dark tremor's script
Can we flash the new kernal version?
yes i did and it works great before i was limited to 768 for max clocking and ive tried the new kernal for both grom and your mom rom (i keep a nandroid of grom) but anyways with the new kernal out im able to overclock at 806 only on your mom, and i must say that i love love love it!
Reactions: noc6285
is there anyway to incorperate live wallpapers and flash? ive tried to install the apk but it fails to work after reboots.. :/
We will make the live wallpapers available as flashable zip, but prob will leave them out of the rom.
As far as flash goes, it will never be included in the Rom. You can search and find instructions on how to add it if you so wish.
im thinking that ill just add it to the rom... lol i give you props im in love with this rom!! :D best ive come by so far! To make it better the new kernal of drews allows me to overclock even more making this the fastest rom ive ever tried in my life ... well on this phone atleast!! keep up the good work im looking foward to the new version!!
Reactions: jstntp
+1 for Drew's kernal. I was just mentioning to him today that it makes ZVH feel a little more smooth like ZVD was....... not exactly (thanks LG and Sprint for that), but closer anyway.
I just updated to ZVH and rerooted and all seems well however I am having a weird problem with xionia recovery. I go through the installation process and all works, but if I try to reboot recovery with adb or by hand using three button start up it seems to skip any recovery mode and goes straight to normal boot up. Anyone every have this issue? I am trying to install MOM now and see if that has any affect. I know I am rooted because I can use SU fine. Any thoughts? I have completely cleared anything and everything I can think of including the sdcard.
thanks,
Mark
:confused:
Status
s1atoshi
