Root Found On Samsung Prevail!!
well if the replenish is anything like the prevail, we havent found a way to flash custom kernels. above and beyond that this phone has a .32 kernel (froyo) it will not work with gingerbread without some major hacking to get it working.
So how does one learn how to flash a custom kernel? I messed around last night for a while with ADB. Turns out "adb reboot bootloader" does not work on the replenish. I imagine this is something all you folks who know what you are doing tried a month ago. Does the fact that this does not work mean the boot loader is somehow locked? Is that also why you can't do the prevail? I imagine they are similar as they root the same.
As for the kernel, does gingerbread only work with newer kernels?
Where could I go to learn about the process you all use to create custom roms and figure out how to flash a phone? I'd love to learn and contribute. Worked as a firmware developer for 13 years, so coding is no mystery to me.
Tested, Working.
Tried with SD card inserted but dismounted, and that didn't work.
Then I removed the SD card physically and it worked perfect, Superuser Achieved!
need help rooting my samsung prevail
I want to start by saying thank you to everybody, I have tried everything and still can't root the phone.
Is there something that i am missing?
I am using windows XP.
Is there a file that i need to install besides the one click root and the drivers
PLEASE HELP
Re: need help rooting my samsung prevail
PLEASE HELP
are you sure you have the drivers installed? go to your device manger just to make sure and debugging has to be on in order for it to work. :-[
Forgot to get a screenshot, but this method worked for my Replenish as well!! It took me about 3 tries...the key was to run the batch file after rebooting my phone, just when the lock screen came up. The times I tried before that, I was getting errors because it wasn't able to create the directories it needed. Superuser and Busybox are now installed...time to get Netflix streaming working on my tiny screen!
how did u get it i keep getting errors but it says i should be rooted but im not please help me out
Thanks to all who worked on this exploit! Now if someone can whip up a kernel and some custom ROMs...:p
Didn't work on my Replenish.
Here's the output of the script:
Please unlock phone, and press enter when done.
You need to enable usb debugging first
Press any key to continue . . .
* daemon not running. starting it now *
* daemon started successfully *
PHONE WILL REBOOT
PLEASE SAVE WHATEVER YOU ARE DOING NOW
PRESS ENTER WHEN READY
HERE WE GO
75 KB/s (5899 bytes in 0.076s)
error: device not found
Wait for phone to reconnect...
mount: Operation not permitted
40 KB/s (4292 bytes in 0.103s)
Copying files onto phone...
failed to copy 'su' to '/system/xbin/su': No such file or directory
failed to copy 'Superuser.apk' to '/system/app/Superuser.apk': Read-only file sy
stem
failed to copy 'busybox' to '/system/xbin/busybox': No such file or directory
failed to copy 'remount' to '/system/xbin/remount': No such file or directory
Setting permissions...
Unable to chmod /system/xbin/busybox: No such file or directory
Unable to chmod /system/xbin/remount: No such file or directory
Unable to chmod /system/xbin/su: No such file or directory
link failed Read-only file system
Installing busybox...
/system/xbin/busybox: not found
Cleaning up files...
"You should have root!"
Please tell me what you guys did to be able to root your Prevail (I have a Samsung Precedent. I'm told they are the same). I come up with the same script that you have posted here. Can't seem to get past it on either an XP or Vista computer. Any info would be appreciated.. :-)
This is now old and outdated. The One CLick app is not available anymore. Found one site that did but you would have to pay about 24 dollars for it!!! dang it! I will keep looking online! :-(
baby boy
