Having major issues... keep getting this message!
rageagainstthecage is in my zip file totally confused not good at this stuff at all
Original one click made by joeykrim and one click installer made by noobnl and f
iron
busybox by skeeterslint
Press any key to continue . . .
rageagainstthecage-arm5.bin is missing. Make sure you extracted the zip archive
correctly.
Rooted for the first time ever!! Don't really know what to do with it besides use "shootme" but im sure I will figure it out.
Thank you!
ugh... having worse problems then the first time i tried to root. keeps saying waiting for the phone to reconnect and nothing happens. tried killing adb in all types of ways. plus there's 2 adb files running for some reason. it restarts on its own after i kill it
question.. i do NOT want to mount the SD card as a drive correct?
edit: errrr nevermind. sixth times the charm
Doing this root procedure will automatically give you ClockworkMod Recovery 2.X.X.X (forgot the exact build number).
my main question is who has been rooted and then installed the 2.2 update manual way and the phone was fine and just needed rerooted. So no issues b/c of the previous root
Correct me if I am wrong here, but this is still RFS, right?
For some reason it won't go root whatsoever at all. I didn't have this problem when I was on dk28. It'll rather give me a string of error messages saying phone is offline or it'll say there is no such file or directory and error out. It mentions having an hd games apk. I Odin'd back to stock before updating via the update.zip. I have no such hd games file on my phone, but remember if I was stock that I should have it. Any suggestions?
No, I immediately updated. It never gave me option to log in. Didn't check though. Guess I should Odin back? I'd like to go back to being full stock. It mentions I don't have the apk for some hd games app and a few more. I think these were added to eclair through an update or something? How can I be restored to stock eclair?
Right. This root method installs ClockworkMod2, which only supports RFS. I've updated the 1st post for clarification.
You can use Odin to flash Froyo EB13 directly, then root from there. Take a look at this thread for the .tar file to use with Odin.
I found online a tar file. I used it with Odin. I went all the way back to DG27
I google "SPH D700 DG27". and I found it. Also you can try to google "SPH D700 DI18". Then use Odin 3.
Thanks, that's exactly what I needed. Forgot to try to google it. I think this may work and help restore whatever files the root method said I was missing...
