Rooting after official froyo
I gave it a try. Made it this far.
Success
* Pushing Busybox
1449 KB/s (1867568 bytes in 1.258s)
* Pushing su
777 KB/s (26264 bytes in 0.033s)
* Changing Permissions on Busybox
* Mounting system
mount: Operation not permitted
* Copying and moving su
cp: can't create '/system/xbin/su': File exists
* Changing ownership of su
Unable to chmod /system/xbin/su: Read-only file system
* Restarting your phone now.
* Complete
Success
* Pushing Busybox
* Pushing su
* Mounting system
* Complete
Temp root didn't take.. what happened when it said executing rage?
Sent from my ADR6400L using Tapatalk
I just read Adryn's post that said you can flash cwm via odin, then just flash the su-busy bo via cwr, has anyone confirmed this method?
Yes - I did this last night and it worked. Make sure after you CWM via odin, boot straight to CRW (up, down, power) and then run the zip you have already placed on the sd card.
Reactions: curley
That appeared to be the problem. Disabled Microsoft Security Essentials and it pushed. Next problem after the push the screen timed out before I could get to it and looks like I will have to start over. Got device not found after it started to try the exploit. Will have to wait untill after work now.
Think I will be doing this tonight and debloat and deodex myself. If I delete Bing Search, will my FS default to Google? It has Google Voice search on it, but I am not sure if the quick key will work.
You just heard this lol, I had it in my sticky For the last five months. Thats it I quit!!!!!!
NO, I knew it worked on the older versions, I just did not know if it would work for ED01. Sorry, didn't mean to hurt your feelings. So Sensitive :'( :)
It is a much easier way to root.
I am having a heck of a time using one-click root. I have looked and I cannot find the OP on how to root using ODIN. Can someone please post the link.
Thanks,
Rick
Thanks,
Rick
Can't get link to work, but check the ROOT FIRST TIME WALK TROUGH. It is the 3rd post I think
Need Help with Root
My facinate was rooted and when the OTA Froyo update I lost my wireless hotspot. I went through the root actions again but still no progress. What are the next steps to solve my issue. The wireless hotspot function says not rooted, and I do not receive superuser request
* Dirrk's EZ Root v0.2 (Sebastien Krahmers Exploit) *
* Testing if your device is connected
* daemon not running. starting it now *
* daemon started successfully *
List of devices attached
I500104bbe64 device
* If you are NOT connected please follow these directions
* Install the correct drivers
* Turn On Debugging
* Check usb port, cable and phone
* Then rerun this application
Press any key to continue . . .
* Pushing the files to your phone
* rage.bin, busybox, Superuser.apk, su, com.sh
948 KB/s (0 bytes in 1867568.001s)
328 KB/s (0 bytes in 26264.000s)
1228 KB/s (0 bytes in 196521.000s)
112 KB/s (0 bytes in 5392.000s)
5 KB/s (0 bytes in 281.000s)
* Restarting your phone to ensure the exploit will work
* When your phone comes back on please unlock it if it is locked and then
* wait for your computer to properly connect to your phone it it does not
* unplug make sure media sync is disabled
I500104bbe64 device
* Turn On Debugging
* About to exploit your device
* This will take about 3 minutes
* If it doesn't respond after waiting 5 minutes then it probably failed,
* so you should close this and run again
* Start Time: 13:00:03.26
** Successfully exploited, installing permanent root files and deleting temp fil
es
/data/local/tmp/com.sh: cannot create /system/xbin/su: read-only file system
/data/local/tmp/com.sh: cannot create /system/xbin/busybox: read-only file syste
m
/data/local/tmp/com.sh: cannot create /system/app/Superuser.apk: read-only file
system
Unable to chmod /system/xbin/su: No such file or directory
Unable to chmod /system/xbin/busybox: No such file or directory
apologies, newbie here again. had the same problem and tried to do adb, but i get "'adb' is not recognized as an internal or external command, operable program or batch file" and just keeps me at the C:\FascinateRoot_v02 path. Am i doiing something wrong? or have the wrong files for root?
still no worky for me..No GPS before OTA 2.2.1 with a BRAND NEW phone....no GPS after. Well I did lock in once in the pacific ocean LOL. I wanted to reroot to use the GPS fix but no go homeys! Ill try to odin it later I guess..
Reactions: T3CH9ICIAN
While I did not do the "official" OTA I did upgrade to ED01 via Adrynalyne Fast way to ED01.
Like you in this thread I was unable to achieve root..
Nemesis2all has a zip over at XDA [MOD][4.21.11] New Superuser package Root your Fascinate - xda-developers
This will give you root access. If you are like me you might need to use CWM via ODIN.
Here is the link to JT1134 CWM tar file [RECOVERY] [3/30/11] Updated ClockworkMod for ALL ROMs - xda-developers
Hope this helps someone, credits go to Adrynalyne, Nemesis2all, JT1134 and of course the whole Dev/Scene..
Murd0ck
one click root problem on ED01
The one click root process breaks down on the mount command as shown above:
I'm hoping for a revision of the one-click root or any other way to root ED01 without using CWM, since that makes future OTA updates a lot harder than just unrooting.
redneckgaming
