[RUU] 4-18-2011 | New Rom + Radio 1.16.00.402 FIXES!
nope its not working. i deleted the radio file renamed the new file , dropped it in my sd card and getting wrong image again. do i need to download an app called rom manager to do this?
You shouldn't need ROM manager. Give me a second to look back through what you've done so far, and I'll see if I can help you out.
That RUU wasn't supposed to be installed through rom manager/cwr
What does your baseband version and software number say?: menu-settings-about phone-software information
Delete the PG05IMG.zip that you just downloaded
Since you have the update radio already, download BAMF 1.5, either the remix, or non themed version to your sd card.
Then follow Cyber Warriors guide on how to flash roms/kernels
LOVE IT!
Thanks for the radio update. This morning when I loaded Waze, it near instantly found me, also my 3g/4g switch is near instant as well. I'm trying the themed 1.5 Remix now, haven't had a single force close nor lag. Thanks for all the hard work guys, love having these fixes rather than waiting on the OTA update. :)
I updated to this RUU but for some reason Titanium Backup / Pro crashes when I start. Has anyone else seen this? Is this a known issue and is there a fix? Please let me know if you need more info.
Thanks
im confused, currently im stock w/root...ive downloaded and deleted the radio file (about 25 mb) several times from several links...once i go into hboot in always starts by saying no image or wrong image (something like that) i continue into recovery..install zip from sd card, find zip, hit install and it comes back installation aborted....should i be selecting the option..(apply /sdcard/update.zip) instead of choosing the zip? should i try to flash the rom first (bamf remix)? would that screw anything up?
I flashed the radio first. You can do it the other way if you want. It could be (and probably is) totally unrelated but when I did it that way I had data issues.
What do you mean "ive downloaded and deleted the radio file"?
The 25MB file should be titled PG05IMG and placed on your SD card in no folders. Boot to hboot and hit bootloader (should already be selected), then it'll start the update and prompt you to press volume up. Do not try and install the radio via recovery.
It kinda sound like the PG05IMG is labeled PG05IMG.zip.zip. Windows automatically puts the .zip behind it. You shouldn't have to rename anything if you use this link.
http://www.multiupload.com/2VDSQ6SBAZ
When you're in Hboot it says you have S-OFF right?
i am on a mac if that makes a difference..put in root of sd card, hboot....fail...
download the radio file and check the md5. if the pg05img.zip file is on your desktop, you can open the terminal program and type:
cd desktop [press enter]
openssl md5 pg05img.zip [press enter]
this will bring up the md5 and you can check that against this value (they should match):
8e166e93a9a72cb7955440720ba8869a
make sure you have s-off, and superuser is in your app drawer. test superuser with a root permissions app, such as shoot me or rom manager.
If that all works, try rebooting your phone a few times and then go back to hboot and try to install the radio again.
What's up guys... I flashed the new stock ROM from the OP... I also flashed the new radio... I seen some posts about BAMF Remix 1.5 ... Forgive me if it's been answered but what's the difference between the rom in the op and the Remix one?
The new radio is GREAT... I didn't get service in my bedroom before... If I did it was one bar... Now my phone still shows NO bars (maybe 1 or 2 at times) but I don't drop calls, calls don't fade in and out, and my data is almost always at 3G and seems to be consistent... From what I can see, this radio has given me MUCH better service... Hats off to whoever made this and a big shout out to the guys who posted it and posted on here... Thanks a lot people!!!
Is there a rooted version of this RUU Rom with the update? I downloaded the RUU Rom w/update and the root was not there.
Thanks
All you need to do is download the radio file itself instead of the whole RUU and boot into Bootloader to flash the file. (Yeah, made that mistake myself...)
Adranyalyn has the 4 files here, they are as follows:
New LTE/New CDMA
Old LTE/New CDMA
New LTE/Old CDMA
Old LTE/Old CDMA
I've been running the BAMF ROMs since 1.5 remix and every flavor for me, the stock radio works the best, best reception and best battery life.
(Currently on 1`.6.3 and their latest Kernal, 1.9)
Reactions: rgm1266
sukarisw09
