Not a dumb question at all.
Better to ask then make the mistakes I did.
File Size is key. The complete RUU is about 300MB.
The radio only file is about 25MB.
The one i downloaded says 399MB. Which is correct?
I haven't downloaded the entire RUU, but it looks from the download in the Original Post, it is about that size, give or take a little bit.
Check the md5 on it, to make sure it matches with the one that is given.
I assumed it was the one for non-rooted phones and all i had to do was rename it, put it on my SD and do the Hboot thang.
This is all too confusing. Not sure if i want the signed, or unsigned.
Does that answer your question? The goal was to help you figure out if you have the right RUU file.
I think you have me in the right direction. So i believe i have downloaded the correct RUU file. Now i suppose i have to find a utility to check the Md5 or whatever. Am i correct in assuming that booting this RUU file on my phone is the same as a regular OTA fix for my phone, just not the official from Verizon? That's all i want to do.
I thank you for your help!
Ok so this is what i did. I flashed the RUU to my phone first. Then i wiped and flashed Das BAMF 1.5. Is this ok? What is this i hear about the 25MB file? the RUU file i flashed was 395MB. I have had 2 reboots since loading all this last night. Once last night and once today?
Any advice would be greatly appreciated thanks!
sorry to ask this again but its all kind of confusing to me. is there anyway or is there a sticky somewhere where it shows us step by step process of doing this? the way corey had it when we wanted to root our tb?
so when i download the file and rename it and put it on the sdcardi reboot and thats it? that gives me the radio update with the custom rom and all the other updates on it?
I loaded this RUU. One thing I noticed and can't figure out why its occurring is a few of my paid apps (MLB at bat $14.99 and Astro Pro) do not switch over or even show up in the market. I believe my market did update itself. Anybody have an idea. Any help would be greatly appreciated. I can't live without my MLB at bat.
First try to install a free app, I've seen it work before where the paid apps would populate after people did that. Not sure why, but its worked.
If that doesn't work try this from xda.
Post 21 explains the process, and post 29 gives a bit more details.
In the future, take a backup of your apps before you flash a new RUU or a new ROM. Use Titanium Backup, or My Backup Pro, either works fine.
