s3 motion and other issues
paulyb37
85
Just wondering if anyone else has some motions not working e.g. contact call not working even with default number set. Other motions work and yes it is switched on! Also on pressing the home button the home screen can take a few seconds to appear correctly i.e. screen and apps gradually appear, slower than my htc desire! Maybe I'm a little naive but I was expecting it to be quicker than this. Wifi drops out occassionally... etc. Any thoughts? Have I got a duff one?
I'm having issues with motion as well...I cant seem to do a screen capture with my palm swiping over the screen?? I don't know if I'm doing it wrong or if it's my phone! Anyone else having issues with this problem?
I've done this and definitely quicker when animation involved but screen still slow to 'redraw' when returning home. Screen capture works fine for me tho.
Sent from my GT-I9300 using Android Central Forums
I think there will be issues with those untill they realease an update for the OS... Same thing happened with the HOX and the WiFi issue... After they realeased an OTA update the issue was resolved
Sent from my HTC One X using Android Central Forums
Fingers crossed. Just a shame that such major selling points don't work. But then how often does everything work straight out of the box? :rolleyes:
Does the side of your palm touch the screen? I was having problems at first but since I tried it touching the screen it works every single time.
For direct call to work you need to either have a contact details screen open.. like the contact card which displays all the details like his or her email... number etc... and then put it to your ear it should buzz and call directly... it also works on the text messaging app.. but i found the message has to already contain sent messages from before to work..
I read that the apps load slowly after pressin the home button becuz the android system doesnt keep the previous screen in memory so it loads it fresh everytime... very annoying
I've tried every screen relating to contacts. It doesn't even work in the 'try it' screen of the motion settings page!
Hmm you may have a dodgy sensor... what about things like if you have dim screen when in a call... does the screen dim when your in a call and you place it near your ear
Good point - tried that and the screen does dim! Strange. Tried again using the 'try it' in motion settings and it just changes to landscape. Getting a stiff arm now!
Well atleast we know the sensor works... i had some problems where my led indicator stopped working properly and i just left it for a few days started working again...touchwiz is very glitchy... not sure why it wouldnt work
Yes these features seem to work when they like... i still think i havent seen the smart stay icon yet... my eyes are dead
I initially had all my motion features working, but in the last few days they have stopped working. Most notably the screen capture motion isn't working.
OOPS! Inadvertently and unknowingly had turned off the "motion" features. Back on now and all working fine.
rrs
