S7 Edge - What do you guys think...about the internal cooling?
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,632
617
113
About the internal cooling system in the S7? I think it's a pretty good idea.
Re: What do you guy think...
I'll be curious to see how much it lowers operating temps at load. Should definitely help with sweaty gamer hand syndrome...lol
Re: What do you guys think...about the internal cooling?
Sounds really cool but how much of a difference will it really make?
I think it sounds really cool... pun intended.
I think it will help not only when the CPU is under load, but also with lag and stutter in the UI (hopefully)
Posted from the one and only Note 4
It's actually pretty fancy. Looking forward to see how well it functions since I mobile game a lot
I'm pretty sure it won't leak, if that's what you mean :-)
However, it also probably isn't very effective. The Lumia 950 range comes with liquid cooling and it apparently doesn't fix the heat issues.
Snapdragon 810 though ;)
I'm thinking one of the big benefits of this will be for those using Samsung gear VR headsets. There's an issue when you use it for very long, the phone overheats and you get a message saying to give the headset a break and allow it to cool down.
I would be surprised if Samsung at least tried beyond marketing hype, since they want to push Gear VR use and the previous devices simply get too hot. Not sure how much they can do though. Small device footprint and same nM chip, but even faster. Interesting.
Omg Samsung so stole this from the Lumia 950xl!
JessAnn
