S8+ and....scratches!
Can anyone recommend a holster for the s8 plus? With belt loops and not a clip?
I like my Spigen case, bought a zizo case because it comes with a belt clip, but, personally, don't like the case as much.
Plus those "clips" always catch on something and break off.
I'm also using Spigen neoflex wet application screen protector. It's nearly invisible but takes some getting use to because it feels like rubber.
So...it's been 5 days and yes, i got a nice around 2 cm scratch on my phone! I was really careful with it, no keys in the same pocket or anything else so i have no idea how it got that scratch (which is kinda deep since i can feel it using my fingernail) but it is what it is now. Although i have to say that my S7E haven't gotten a single scratch.
So, anyone used cerium oxide? I kinda want this scratch to be gone, otherwise ill be replacing the screen!
Any ideas?
Just leave it alone otherwise you'll make it worse. You'll get used to the scratches. Another thing you could do is resell it and buy another one which is the safer route.
I Had an iPhone and went to and S8 love the way it looks I didn't want a screen protector I got a otterBox but it doesn't have a Built-in screen protector sales guy at the store suggested this so far it works perfectly knock on wood I haven't had a scratch on the glass or anything feels like it has nothing on it at all no kind of film or anything it went on pretty easy almost like magic wipe it clean dry it then wip this stuff on it and done. Will have to see how it works. They'll cover it if damaged well up to 100$
I have this also. Using it on the front and back of the phone. Since it takes up to 48 hours to cure I haven't used a case in 2 days. Have been sliding my phone in my Sena pouch instead.
heritagevines36
