Samsung Galaxy Note 6
A friend of mine works for Verizon. Told me to hang tight for the Note6. The Samsung S7 is getting SD card and removable battery. She believes same with Note6. If not then unsure what I will do. Those are two I can't be without
Even though I still have my Note 3, and rumors are the 6 will get an SD card and removable battery, I think my next phone will be a Nexus with the new ones later this year. As long as the internal memory is 128 or more. I may give up on the removable battery possibility.
I used to complain about not getting the updates. Now I believe if you don't have a Nexus then you don't have a right to complain about not getting the updates.
The new Samsung phones have been introduced, and they have the sd card slot, but no replaceable battery, although the battery is 18% longer lasting. As i've said before, i have a Nexus 5, and i've had 6.0 and 6.1 on the phone for a while. Getting early updates means nothing if the updates are meaningless. 6.0 is just a jumped up 5.? :p
The s7 looks amazing but I think I'm going to wait for the note 6. I currently have the edge 6 plus and love it. Will, the note be out in September?
That's a good point about the updates. I looked at the new ones that just came out but the screens are smaller than my Note 3. Idk if I can go smaller any more. But I think I'm ready to move to a Nexus anyway.
What is this I'm hearing the s7 will be only a 32 gb version
Hope I don't wait on the note 6 and no 64 gb versions available.
In Perth Australia they didn't have a 64gig for the note 5 but they did have it for S6 edge plus. I've only had it for 5 months so happy to wait for the note 6 if it is Decent.
I hope it's water proof. Expandable memory is ok (special with my go pro)
I want to see them go back do what made this series stand out from rest, huge usable screen. Everyone has 5.5" and 5.7" screens now. 7" 4K would be perfect and make a statement. With SD slot and 5000mh battery, I'll dump my Note 3.
If Samsung cut their edge series in half, I wouldn't buy one
Don't like the edge series phones period.
It made the screens not look as wide.
And they want 100.00 more.
I don't like the narrow screens.
They need to be wider.
The Samsung people at Best Buy didn't even have the edge.
7" screen would be a tablet. No thanks
Putting one in your pocket can break through motherboard too.
Then you start having problems & wonder what's going on.
Definitely a larger battery if they decide to go non-removable. Is 4000 mAh asking too much ;)
An OS that doesn't hog the processor.
Cheezy313Bby
