- May 26, 2011
- 1
- 0
- 0
I just got this phone and it looks like it has a major issue (unless there is a setting to control this).
Anytime you make a call, even to your voice mail, the phone immediately double locks (?!) itself. This means that a lock shows up on the screen and you have to push the button on top and after that use the standard unlocking (with the slide). Same when you receive incoming calls - instead of using the slide only to start the conversation you have to push the button on the top as well ?! This is so frustrating, my old iPhone 3GS doesn't do this (not even a single lock). Can you imagine this - just preparing to use the dialpad and suddenly the phone is locked (twice). I thought it might be Android or Samsung feature and asked my friends about it and nobody knew anything about it.
Probably somebody already figured out how to get rid of this unwanted lock, hopefully there is simple solution. Otherwise the phone is decent for the low price plan of Boost.
Thanks for your help
