Screen goes blank during calls
That's good, Morty. It's something you don't want to experience. Very annoying, a real PITA.
I'm sure! Especially when you're in the middle of a call (which is important in and of itself) and need to put them on hold, speaker, etc.
Apparently it is a known bug
The Register: Google says Pixel 2's narcoleptic display is being fixed in June update.
https://www.theregister.co.uk/2018/06/18/pixel_2_call_display_narcolepsy/
Actually, in your particular case, as evidenced by the fact that your proximity sensor tested normal, and was capable of functioning normally, the issue was indeed attributable to the bug. However, in the majority of cases where the screen goes black and stays black even after the call has ended, it's because the proximity sensor is either faulty or it's being blocked by something. That's why testing with AndroSensor or a similar app is important in sorting out the cause of the problem.
My screen goes blank during calls too. Started with the Pie update. Sensor is fine. No screen protector or case.
This has only been happening since last update. So I know their connected.
Yep, same for me, only happened since pie update and unbelievably frustrating bc it basically disables my phone when I take or make a call. Impossible to make a call with a business that requires you to make selections with your keypad.
It sounds like you have a "stuck" proximity sensor. Grab an app that can display the sensor status (I use Elixir2) and see if the sensor is detecting object presence when there isn't any.
Once that's determined, if it is detecting objects, I can't say how to fix it, but you at least know where the problem is. You could try it in safe mode to see if maybe an app is causing it.
More of a quick temporary fix but, this started happening to me on my pixel 2xl, I double tapped the power and pulled up my camera, everything went back to normal. Until the next call that is, but it's a work around till it's fixed. I hope this helps.
bruce03510
