second screen doesnt work with nova.
Did anyone have problems with nova and icon placement? Like its impossible to put icons/folders on the 2nd row from the bottom
It's very finicky. I tried for an hour when I first set it up and every time I'd try to put a folder on the bottom row it would end up in the dock. Just keep at it. Eventually you'll find the sweet spot and it will drop where you intend it. Look for the arrows. When they aren't pointed up or down, it will drop where you put it. Very frustrating to get it right though.
I posted about this as I use Nova Prime as well. If you turn on Hide Notification bar it will cause the second screen to not work only in your home screen. It will continue to work if you're in an app or in the settings menu.
That's the annoying part. I want the quick icons and contacts and music player to work on the home screen with out the notification bar. I want to use it in conjunction with klwp.
Anytime the status bar is hidden on any app, the second screen either turns off or it displays the time. That's how LG programmed it.
This makes me wish I could disable the status bar in all apps. It's not necessary with the second screen, in my opinion.
probang
