So yeah stuck in bootloop need some help
Jaredshoes
457
30
alright i was trying to flash Skyraider 4.0 today and did every step in recovery when i rebooted i was stuck on the white incredible screen so im like yeah forget this. i boot back into recovery and load up the backup i had just made this same day it was Cm7 Now im still stuck at the white incredible screen, what did i do wrong? :-\:-\:-\:-\:-\:-\:-\:-\:-\:-\
How long did you wait? Especially when I flashed slyraider it was about 10 minutes waiting for it to boot.
I agree sometimes when flashing a new ROM i have had to wait at least 10 minutes and it will be the LONGEST 10 minutes of the day!!! :) Try again and just walk away from your phone for at least this long.
Trust me :} ive done that i went to play some xbox and 30 minutes later still in bootloop :]
I have a similar scenario. Dl'ed thru ROM Manager, told it to wipe. Get boot loop on CM7 screen. Now I am in able to boot into recovery. Device just vibrates 3 times and stays black. Any thoughts?
Pull the battery reboot and be sure to push the volume rocker the right way when you go to boot it. Up if I remember correctly download from the source onto your computer load onto your SD card even if you have to pull it and manually load it through a reader. Boot into recovery do a factory reset wipe the cache and in advanced wipe the dalvik. Flash your chosen ROM in recovery and all should be good. I haven't been able to get ROM manger to work for several months now so I just uninstalled it and do all my flashing and backing up manually in recovery now much less a chance for error.
Did you get it to restore? Did you flash manually in recovery or use ROM manager? If you did use ROM manager I would try in recovery with a freshly downloaded copy of whatever you are trying to get running.
nah had to go back to stock ( still rooted) but even both my cm7 backups were corrupted im gonna get a new 16 gb SD card soon because i cant live with 2gigs maybe it has to do with psace on the sd
DonUAE
