sound through handset
darkstar
80
ok.. i dont know how i did this... but my sounds are now coming through my handset instead of the external speaker... like soundboard, ringers, notifications..... how do i fix that?
lol
thanks!
Did you install any apps that could mess with this? If so, check the settings menu in them...
i popped my battery off and restarted the phone.. back to normal.
Thanks for posting the answer to this problem. The sound through handset problem happened to me after I started adding media to my phone using the USB. Not sure if this was root of problem but will let you know if it happens again.
alexhkjdfskdfhksdjfsd
