Sprint Lollipop!
Anybody know the difference between these two connections optimizers?
Anyone know the difference between these two connections optimizer? I know one from Sprint and i was able to turn it off, the other one, i don't know where it's coming from as I first saw it with lollipop, but i was able to disable it.
Any thoughts?
I noticed the "Power Settings" widget - seemed to be stock android was taken out with this update. I liked it, the HTC widgets don't have wifi & bluetooth on the same widget. :(
For a few seconds there the Lollipop install was eerily silent and I feared a brick. But your positive results reduced my fears. Thanks everyone for early adopting and reporting your results to the forums.
Sense 6 on Lollipop is really really nice.
Also downloaded last night on my Harmon Kardon edition. Very nice. No change in battery life for me, but I have Connections optimizer turned on and use most of the power saver features. Lock screen Smart Lock took a little getting used to. Not used to waiting for the lock icon to change to a silhouette and then back to an unlocked icon. But now I have it figured out. I have used Battery Notifier Pro forever. It no longer is visible in the notification bar when the screen is locked, but it does show up as an annoying notification in the middle of the screen. Sure, I could use the battery notification from the Power options in Settings, but I am a creature of habit and like the app, though now less useful than it was.
All in all, not a bad update. Still love the HK sound with the HK headphones.
I've noticed it's notably smoother than kit Kat.
I actually noticed that myself!
Kit Kat did seem to be a lot more lagy...everything does seem to be a lot more smoother.
Also, I have to say that I really love the notifications on the Lock Screen! It finally makes the Lock Screen useful!
Another thing that I like is that the quick setting menu and the full settings menus are much easier to access.
All-in-all, I am really happy with the upgrade!
Avanish09
