Stock Pre-Rooted Deodexed Zipaligned Png Optimized EC05 Tar 4/7/2011 Fixed Both Tars
well it over wrote it, and i fixed permissions and same result, its not wheather its a contact in my phone, its if i hang up first, if i hit end, it FC.
hmmm.. any other ideas?
bingo, u da man, running this with genocide kernal, total sickness
edit, i could never get above 1.2 before this mod i was nevr on ext4 so this is great
Ok I have fixed both tars and I'm currently reupping.. but thats a slow process.. I also changed the kernel in the mod EC05 to Vision Kernel, to prevent any future FC issues, and it also goes to 1.4 and adds voodoo color.. I'll change links and update OP when uploads are complete
Is there a patch for the ext4 version to have the default sprint boot and shutdown animations?
Sent from my Epic 4G using Tapatalk
You can get the stock shutdown animation, that wouldn't be a problem but the boot animation might be a problem because of the kernel.
The custom kernels disable the ability to play the stock boot animation and play bootanimation.zip instead. But there is a bootanimation.zip that closely mimics the stock bootup animation, when I get home ill post a zip to restore stockish bootup and shutdown animations
here is a zip made by nubecoder on xda that puts a blank bootanimation.zip then restores the stock boot animations and makes it where they don't overlap.
xda-developers
i'll post a zip for shutdown in a few minutes
I saw your post on XDA for the shutdown animation. Thanks again.
When I check my kernel version in the system menu, it says Vision Kernel 1.0 and not 1.1
Is this correct?
Also, is there a way to restore the audio for the shutdown animation?
It was my mistake. It was in the package. I forgot to replace no with yes for this package
Is this correct?
it is 1.1 but he just didnt update the version line in about phone i guess..
the audio is there, i dont know why it wouldnt be working... give me a second to figure it out..
The boot has the sounds, just not the shutdown. Everything else is great.
Vicarious1
