Straight Talk apn settings for AT&T Samsung Galaxy S3
Re: Straight talk apn settings for at&t samsung galaxy s3
I just got off the phone with straight talk .
Their settings have changed again .
APN tfdata
MMSC: http://mms-tf.net
MMS Proxy: mms3.tracfone.com
MMS Port: 80
MCC: 310
MNC: 410
I ordered a phone online. i got it off of ebay. it's brand new. and i believe its a samsung galaxy note (it was new from china).. i am able to get online, and i can send/receive phone calls and text messages. but i am not able to send/receive picture messages.. what exactly should the apn settings be? i tried to call straight talk, but they werent really much help....can anyone help me please.. im not very phone smart and im about to give up... its model number a7100
I've done just as you stated but it hasn't worked for me.
Having the exact same problem , no matter what I try it will not work
Thanks a lot its a great help to me..
God Bless Bro
Are you guys seeing 4G LTE using these settings?
I got a push from AT&T last night with a software update and now I can't get any data. I checked my settings and set them as listed below:
APN tfdata
MMS Port: 80
MCC: 310
MNC: 410
But I still can't get data. I called Straight Talk and waited forever and was then disconnected while talking to support. It was clear he was clueless though. Had me restart the phone about 10 times and then check if I could get data.
Anyone else had this problem?
Try this...
i JUST got off the phone with straight talk (took 5 minutes) I have been using ST for over a year, my Galaxy skyrocket puked, ordered a brand new unopened S3 -SGHi747 for ATT unlocked.
the settings they gave me and are 100% working are as follows:
APN settings samsung galaxy s3 (ATT unlocked)
Name=Straight Talk
APN=att.mvno
Proxy=proxy.mvno.tracfone.com
Port=80
MMSC=http://mmsc.cingular.com
MMS proxy=mms2.tracfone.com
are the ONLY changes i made. SAVE new APN, switch to new APN,reboot and WALA
I HOPE THIS HELPS SOMEONE as i have been scouring the web for a couple hours, and had it partially working. then the APN dissapeared(weird).. decided to CALL THEM
as i said it took literally 5 minutes!! they need to update this info on the website, as what they have for ATT phone there is incorrect.
:mad:
I have an unlocked at&t Inspire and the only settings that I can get to work for everything using Straight Talk are posted from Christy (comment #27)
APN: tfdata
MMS Port: 80
MCC: 310
MNC: 410
Hi, I will ask this so that if any of you can help me, I have a at&t home phone (contract) this uses a sim card, the equipment is having troubles, can I use this sim card in a cellphone? in a android one? I try to use it in a samsung galaxy 3 and ask me for the unblock code. Thanks for any help.
I have tried this and I have the same phone and same straight talk network but the apn settings didn't work I have tried several settings but nothing I need help someone because I would like to use the Samsung galaxy s3
Name=Straight Talk
APN=att.mvno
Port=80
I am having the same problem. My phone had a software update, and now it is saying that I can't send or receive pictures. My internet works, and my regular text messaging works but I can't send or receive pictures. It is pissing me off quite frankly.
I'm having the same problem. I went in to view my apn settings and it won't let me open each one so that I can make changes.
i have an att samsung galaxy s3 that I am using on straight talk. I can make phone calls, send text, get on net, and have 4g service. It shows that i can send mms and receive them but they will not download or open the pic on my phone. I have tried every apn combo i could think of and I just cant get the mms to work right.
this is what my apn in now
apn= tfdata
proxy= proxy.mvno.tracfone.com
port=not set
username= not set
password = not set
server= not set
mmsc= http://mms-tf.net
mms proxy= mms3.tracfone,com
mms port- 80
mcc=310
mnc=410
authentcation type= not set
apn type= not set
bearer = unspecified
someone please help ST keeps telling me oh some phones just cant do mms. which i know this phone works fine since many of you on here have gotten it to work.. thanks again
so I finally got it to work with these settings
APN: tfdata
MMS Port: 80
MCC: 310
MNC: 410
also an important not you need at least 3 bars of service to receive mms messages.
does the s3 have to be unlocked?? i'm fixing to buy one from someone and don't wanna purchase it if it has to be unlocked. i wanna be able to put my sim card in, enter the info you gave, and use my phone..
no you do not have to have an unlocked phone/
Amber,
You may want to be careful with your purchase - if it's a Verizon model (SCH-i535), you should give it a pass.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
Worked for me...Thank you very much for sharing!!
Well almost...I have 4g and internet now, but still can't send or receive mms messages. Getting closer I suppose.
iheartpenguins
