T-Mobile users make sure you're using a 5G SIM card.
Changing SIM Cards does NOT change your phone number (unless you want it too).
I would call customer care, or take it to a store, and have them activate the NEW SIM Card in the N20U on the line you want to keep the number on.
It's not hard or much of a hassle.
Shhhhhh..
Currently I have my sim from the Note 10+ in my Note 20U unlocked version and there no standalone alone , I'm going get the newer sim see if that gets it .
I can report that with the new sim I've noticed no difference in speeds. SA may not be available in my section of NYC.
Pretty easy to do online as well. Took me just a couple of minutes to active the the new SIM and swap it out.
You get 5G in the area you in ?
I'm in jersey , so far 5G mostly were im going.
Is there a separate toggle now for the 5G ?
Can you post a screen shot of network page ?
From what I understand you need the SIM and an update that hasn't been released yet for the N20U. I have not seen a difference with just the SIM in San Diego.
I believe your correct, and supposed to be in September update
Now if tmobile would release that update. Still don't understand how an unlocked phone has to wait for tmobile to release the update. Also waiting for esim activation update. About to get stationed in Japan and want esim for my American number and physical Sim for a local number.
Yes, I get the 5G icon just about everyplace I go in NYC.
Yeah it wasn't like that before the unlocked would drop to all carriers, but esim not available on US Samsung.
I updated my SIM although they told me I didn't need to. I had to call a second time to use the new SIM. I don't get 5G coverage at home, so I have to go out and about to test it.
I watched the video from Samsung about the UWB module and they were saying the esim was built in with that. I also looked at the specs before buying and they said had esim. I hope it does I need 2 Sims.
US carriers for some unknown reason turn this off , international version have it .
It has the capability , but US carriers turn it off for their phones , HongKong is a different region . You can check Xda if anyone found way to enable it on .
I will and if not hopefully somebody will or we will get an update that will enable it.
Qtinopu
