- Oct 21, 2013
- 1,806
- 0
- 0
This thread brought to you by the Department of Redundancy Department
Sent from my SM-N900V using AC Forums mobile app
The only thing I dislike about the rear buttons are the very few occasions when I want to access the power menu. Aside from that, they're great. Still getting using to fingering my way around back there to press the right buttons.
Another benefit is that between the rear buttons and knock code, you really don't have to worry about nosy people getting into your code.
Sent from my LG-D851 using Tapatalk
You do eventually get used to it and once you do it kinda makes sense.
But this is of course up for debate just because I like it, doesn't mean all will.
Its just become so natural so much so when I pick up the Z2 I'm trying to knock off and then realise it doesn't have that feature (has knock on).
Then volume key are obviously on the side of the Z2.
Much more responsive than the G2's knock feature
I need your help guys! I am planning on buying either the Z2 or the G3 - looking at the above posts, it looks like the G3 is winning. I need a good camera, I'm currently using the G2, which is why I'm not instantly choosing the G3 - it doesnt look like a massive upgrade from the G2.
Is the Z2's camera bad? or does it just take some tinkering about with to get the right photos? I've had the S5 for about a week and sold it, nothing exciting about the device.
Hey Kevin well I can't put down the G3's Camera over the Z2's.
What I can say is both produce great quality pictures.
The Z2 has more features and even in superior auto it takes great photo's. Has the dedicated shutter button (which I like).
Both are great and whatever one you decide on purchasing you won't be disappointed.
thanks mateI'm really considering the G3 now haha!! I guess i'll need to pop into a local shop and see which one works best for me.
Cheers
Kevin
Thanks for the insight. I'm actually returning the G3 and ordered the Z2. Is the phone I always wanted. IR blaster and Qi would had made it prefect. I hope I like it. I hour the pic quality is as good as the Lumia 1520. That phone took pics.
Why you returning the G3?
