Things you don't like about LGV10? :(
Here is another
When the phone is charging, the screen shots don't really help to isolate anything. Charge to 100% so that the stats reset, then as you use the phone, you can post screen shots as it discharges, preferably after you are down to 75% or 50% battery remaining.
Everybody is talking about great things they liked about the V10. We all know how great this phone is but is there anything you don't like about the V10?
The fact that the awesome speaker sound is only when headphones are plugged in. I want great sound all the time! I don't use headphones!
The fact that I have to plug in the phone 2-3 times to get Android Auto to start. Other than that, it's a great phone to me.
U can use the DAC fix app. Let's u use hi-fi DAC with others apps like spotifiy and Poweramp and more
---- danny 5
My friend is using lg v10 from last 2 weeks and he says it is an awesome phone with small display, steel body superior sound and very crispy display and at the end its camera is too awesome its new image taking options is nice.
Wow... My V10 works great. I can go all day and still have 45% battery left. I add always close all my apps when done.
I wish it had the quiet hours feature built in the OS like the Lumia 928 on Win 8.1 I came from. If anyone can suggest a GOOD app for quiet hours it would be greatly appreciated.
Call blocking native to the phone, also would be cool. I bought Extreme Call Blocker yesterday, and am hoping it is a good app. I have my number in the "do not call" list but it would seem that is not enough for some.
You can set "Downtime" and chose to get no interruptions or only priority interuptions that you select. Is that like quiet hours?
It's under "Sound & Notification" settings and then "Interuptions"
So are you happy with your v10?
Ryan Johnson - Man, I am loving this phone! My Lumia 928 was doing the job, just the speaker issue was bothersome. I may get it fixed if costs is not excessive. Keep it as a standby.
This is 98% THE PERFECT phone for me.
No major complaints really, only very minor ones.
>Slightly smaller overall size.
>Water splash resistant. My Sony Xperia Z3 and iPhone + Lifeproof phones were. Hopefully Lifeproof will make a case for this phone.
>I wish I could fit more contacts and app icons up in the secondary screen. Maybe replace the "Recent apps" screen with an open page where I can drop in anything I want.
For those of you unhappy with your LG v10, why didn't you take it back??? You had 30 days to do it!
So, it's your own fault if you didn't... ;)
I took mine back and got a 6P. Could not be any happier!
The dual window option can only be used with a few types of apps.... email, text, memo-notes, picture viewing, file manager and google drive. Whats the point of having two apps open that I don't need? This is a let down, given the amount of hype this feature has been getting as a multi-tasking hand set.
gruptysh
