Things you don't like about LGV10? :(
With regards to the weird lock screen clock... See this:
View attachment 205990View attachment 205991
One picture is what the clock looks like when there is a notification on my lock screen. The other is what shows when there is no notification.
That all being said, I have not seen a setting to change this.
For those that haven't figured this out, the weird clock screen issue is just a setting in the phone.Settings -> Lock Screen -> Clock
^^^ This reminded me, I don't like that the notification icons disappear when the lock screen comes on. I wouldn't have to bring up the lock screen to unlock the phone and check for notifications if the backlight of the highly advertised second screen wouldn't dim so much that I can't see it 99% of the time.
I don't have that Clock option and also mine doesn't show the charging time remaining. My G3 I had before showed it. I'm in AT&T
It's in MM, explaining why you don't have the option yet..
Posted from my LG V10 (VS990)
When I accept the invitation to put app shortcuts on the lock screen the shortcuts attach just fine but don't work. Confusing.(
Wait, there is no wireless charging on the V10?
You can easily add wireless charging. I did it to mine. You can either get the wireless charging receiver sticker or buy a backing with it already on there. I got the backing for $12 on amazon and then purchased a wireless charger yootech $11. Worked like a charm.
To the poster with Blue tooth issues, It might be your phone...I have no popping issues; rather, quick BT connect and perfect sound.
One issue I have is Skype...I've never seen a phone that has issues with Skype: I freeze or turn green frequently.
Everything else that I use is great.
My fps is "sometimesy" on my v10...sometimes it won't register my finger print and I have to re-add the same finger again ...
If you're using a case then try registering your print without case and then add the case and see how it responds.
Other have mentioned the primary things...battery is not great but it's OK for a modern smart phone. About comparable to the Sammy S6. The no LED thing is just weird, but I understand why with the second screen.
To add a couple of quirks, the two cameras on the front in certain light look like notification icons when you first glance at the phone and so I find myself thinking I have a message when I don't (again, see the no LED thing). I have the black on black so perhaps other colors don't do this. Also, related to the second screen, when watching video in landscape mode, the second screen in dark, which causes weird chunkiness to the screen as there are two right angles involved.
I also wish it had the fast launch camera shortcut that the S6 has. I liked double clicking on the home button to launch the camera and wish all phones had a similar short cut.
EDIT: Forgot my primary gripe. They HAVE to open up the fingerprint reader to third parties so that it can be used as security. Not being able to open LastPass with my fingerprint sucks badly after doing that for a year with Samsung.
But overall, I think it's a great phone. The removable battery and SD card is great and I feel very comfortable without a case.
As for the camera shortcut you double tap the volume down button twice and your camera is available
drayb
