things you notice after installing leaked froyo for droid x
The only gripe I have is the battery manager fc's on me when I click settings. Other then thus, all id good on froyo.
Edit: I did a reboot and now it works. Not really sure why but now I have no gripes......lol
dont know if anyone else has noticed but when I would get a gmail notification and open the email if I just hit home from there it would not get ridof the new email notification, I would have to hit back to the inbox or delete it. Now soon as you open msg it goes away.
That used to bug me.
My video camera crashes every time now. Pandora widget stops working a lot. Overall very buggy I need to get 2.1 back.
I just had two updates fail. When I go back to try again the app says free, as if it's not installed already. If I install individually it works.
Not sure if the items with ? marks after them were there before. Just noticed them myself.
  • Cannot turn off SD card notifications in Sound settings.
  • New Polar Clock live wallpaper (?)
  • No longer able to disable screen lock {grrrrrrr}
  • Option to use Power button to end call (?)
  • Several apps will not install due to this being an unofficial release: Touchdown key, Docs to Go key, Flight Track app/key & Remote Tunes to name a few. All apps I use constantly, of course.
Launcher Pro Plus still adds a lot of value - will never give that up.
Hey Cory for what its worth I had my "disable lock screen" checked. So when I installed 2.2 I no longer have a lock screen anymore and can not re-enable it. not that I want to.
Has anyone else mentioned the absolute minor upgrade of the smileys menu to little Android graphics that represent the symbols? I thought it was pretty sweet.
I was wondering, have anyone loaded the older Beautiful Widgets with the Sense UI clock on their phone with the Froyo 2.2 leak installed, is it compatible or will I have to use the update and loose the original Sense Flip Clock design? I really like this layout better than the updated version and hope it will be possible to use it.
My camera keeps crashing all of a sudden, but the good news is I discovered that not only do the headset controls work for the native music player, but also for Pandora as well which is pretty awesome.
Also (finally) when one source of media plays, another media process that is already running will pause. So now if I want to switch from music to Pandora, I dont have to pen music, pause, then launch Pandora.
Can anyone confirm that they can add Speed Dial numbers to all 9 slots then try using them. On this build Speed dial umbers are not saving after slot 3.
I have basically the same problem. I can't add speed dial to any slots. I was able to delete the default *86voicemail from slot 1, but I am unable to add it or another number back. I currently am unable to add a number to any speed dial slot. Basically the only problem I've encountered since the upgrade.
Another awesome feature, you can automatically rotate a pic in the gallery with two fingers.
Has anyone used this and can answer this question?
sarahsda
