- Mar 9, 2012
- 169,692
- 11,112
- 113
Middle finger...
Sent from my Droid RAZR MAXX using Tapatalk2
Hey, who you flippin' off?
Middle finger...
Anyone else have this calender issue I mentioned above???
Sent from my DROID RAZR MAXX, but webOS is always in me...
Are you using the stock calendar or the Google calendar? FWIW, mine (using Google's) seems fine as far as I can tell. I should add I don't use the widget though.
I am using whatever calender is on the phone, which I assume is stock. Widget or no widget, the problem is the same. The calender sometimes displays properly, other times it doesn't show anything.
Who knows? I'm betting it will be gone in future builds.
Future OS builds? Unless there's a security update required, the DROID RAZR is done getting updates.
Have you tried clearing the cache partition?
http://forums.androidcentral.com/showthread.php?t=212407
How to clear your Cache (stock)
Sent from my DROID RAZR using Android Central Forums
The cache trick seems to have worked. The only thing that's still bugging me is the key board and auto correct. It seems a bit off compared to before.
SDMAS President
Sent from my Droid RAZR MAXX using Tapatalk 2
