[Tool] Root 2.11.605.9 and .19, no downgrade or data wipe!
Ah, The instruction that said to make sure the phone was on charge only was a little misleading, I thought I was to have my device plugged in when i started the process. thank you
You should have it plugged in, its just that I think you were having a random error and I just had you unplug it just in case l
Sent from my mobile look-at device
Ah, well thanks it worked great!! Man, superuser looks A LOT different than the Eclair days... wow.
Superuser didn't install on its own, I had to go to bootloader to load CWM. Not an issue, just letting you know it didn't.
The popups said to tell rev to do it
I entered 'Y' when prompted on Revolution. HBOOT just didn't automatically load CWM. Still the easiest rooting process I have seen for the thunderbolt. This is awesome. It actually might have been easier than rooting my droid 1...
OH! haha I get it now. Thanks :)
Yeah sadly rev doesn't reboot to recovery, had that in the pop ups also... Just wish there was a way to automate it
you make it too easy bro. Took all of 5 minutes. I remember rooting when jcase first got root and s-off on this thing and look how far we have come, or i should say the devs have come. thanks again for your work, and also the help with getting the borked device back to s-on earlier. cant thank you enough!
Reactions: trter10-imore
Hello everyone. I am new here and any advice would be greatly appreciated : )
I did everything right up to flashing the recovery over fastboot. Now I selected bootloader, waited a few seconds..but before i could go to recovery what happened was this..
it says 'checking sd image'
image load failed' 3 times and then it gets stuck at:
HBOOT
parsing.. sd zip
1 mdm9k
2 radio_v2
do you want to start update?
vol up yes
vol down no
Please help me out.. also now my HBOOT is 6.04.1002 because i think i hit vol up the first time it came up thinking that was the recovery flash..
What do I need to do at this point? Thanks again everyone thank you for everything that you do :)
HBOOT
parsing.. sd zip
1 mdm9k
2 radio_v2
vol up yes
vol down no
Reboot your phone and remove the PG05IMG.zip off of your SD card. Then power off and held volume down and power until hboot shows, wait a few seconds, then select recovery.
Sent from my HTC Thunderbolt
Reactions: denden024
When I run the program, it doesn't move on from the "Waiting for device..." step 5. After checking to make sure the MD5sum matches (it does), installing (and even re-installing) the fastboot drivers, I've tried restarting computer and phone, turning off firewall, checked for the PG05IMG.zip, and even moved to a different computer to try it all again but came up with the same issue. I can't figure out what I'm doing wrong.
Any advice???
Any advice???
Is USB debugging enabled? Try disabling and re enabling
Sent from my iPad (the one with no name :P ) using Tapatalk
I'm struggling big time. I used your tool to root about a month ago. Received the OTA but denied it as I'm worried will brick phone. I downloaded 2.11.605.19 and put on sdcard. In Hboot, it asks me to download update and it appears to unzip and download but I'm still at 2.11.605.9. Can I flash this software right from hboot or do I need to flash from CWMod from sdcard. Very confused
pamatika
