Trouble with this website
It's another Tapatalk issue, my guess.
The post stays highlighted when I back out. It's been weird. Did it post - did I lose it?
I guess that pop up message is easier to capture.
I may express my displeasure officially if it continues for a few days.
It certainly wasn't doing this earlier as I posted myself today and didn't get the error .
So I just got that message pop again, I missed the screenshot but this is what I get next.
The post stays on screen even though it has really posted, so you click send again and this:
Every time now. So you got to Send, then when nothing happens, exit and select Discard as it already posted.
On Edit :
I was just going to say the same thing.
How can we split this thread in to another one.
I'm going to report my own post for a moderator to take notice and decide about that :)
//images.tapatalk-cdn.com/15/06/14/e5b5646d63d4d02557cee8ba88da53d0.jpg//images.tapatalk-cdn.com/15/06/14/ecc4db799dd617b75e9371e0123e2d72.jpg//images.tapatalk-cdn.com/15/06/14/52ca740f59bffadd9ceb0ab848f84794.jpg
I got that too when I hit on send again.
Sent from my D5503 using Tapatalk
I'm going to report the issue officially to android central.
Last addition: I definitely Liked 2 or 3 posts, and they appeared as Thank's.
I also DEFINITELY Liked and Thanked Jalopiejoe on the Note 3 forum yesterday and they disappeared today from that post, so I put a like again.
Why do we need this thread split? I would think a mod etc will be able to work things out and get the jist of the issue.
I've just reported the bug issue to them here at Android Central.
I copied the thread of this forum to them so it'll be a good idea not to start moving this thread in anyway till they have seen it and dealt with it.
I'm sure that they will fix it soon.
Just thinking that it could be tapatalk related as there is no similar issue using web version only tapatalk incorporates the bug I believe.
Because I wasn't aware of this issue when I first posted a question earlier I ended up with 3 duplicate posts, I've since reported 2 of them requesting that they be deleted, my own created threads of course.
And I'm still having the original issue for which I started this thread if I enable Shockwave Flash in my IE 11 add-ons. If I turn it off, the Android Central site works fine. If I re-enable Shockwave it freezes, flashes and causes IE to crash. Doesn't happen on any other site and just started a couple of days ago. I also checked the Shockwave site and it says I already have the latest version 18.0.0.160.
Hopefully they will read all the comments on this thread, if not then I suppose like others have previously indicated this thread will require to be split into two, but trying to keep the original feed link especially for the second issue because I have sent the direct thread link to Android Central support.
Are there any mods working on here at all?
The errors you've been experiencing should be gone now. Give it a try and let me know :) Thanks!
Oh, by the way, what about the duplicate posts that were a result of this?
Also, should I be able to delete my own post or thread on Tapatalk for this forum?
Ishimwe
