• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
Turn on Quiet mode/vibrate when LG G2 locked
msalamon
Just got my LG G2. seems great so far.
One thing I cannot figure out is how to silence the device quickly once the phone is locked. I don't mean to silence an incoming call. Right now I have to unlock the phone and use the volume buttons. Other phones always had a slider on the locked home screen where I could turn the ringer on or off. but the LG does not have that.
KellyOYeah
Active member
Jan 6, 2012
28
Push the power button twice...like you were going to power off.
Sent from my G2 using Tapatalk
msalamon
That does not seem to do anything. if i put the volume to the bottom, it shows the vibrate icon at the top, but the double power thing does not do that.
TheSkipperCDB
54
The notification settings on the notification shade include one that toggles sound/vibrate/silent, and another to toggle quiet mode. You can organize the quick settings icons. Then from the lock screen, pull down the notification shade and toggle the appropriate setting.
mannw1977
350
10
Press power twice but hold on second push. The option will show as needed. Bang baaaaang and quitness is yours.
dstackmasta27
22
Alternatively you can use power toggles and add a widget to the lock screen. That is what I went with, although the power button way works too
